Results 1 to 7 of 7
Thread: Webcam brightness issue!
    Sep 2006
    Cornwall, England
    I am going to use a USB webcam for a reversing camera, but when I put the USB webcam outside the van, all I can see on the screen in white. If I put a sunglass lens over the webcam, i get a picture on my screen.
    At night though, with the sunglass lens infront of it, i get a black picture. I have written my front-end in VB.NET, is there a way setting white balance on a webcam through VB?
    ViVE - Volkswagen In Van Entertainment:
    VoomPC 2, VIA C7 2GHz
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    [||||||||||] 100% - Planning
    [||||||||||] 100% - Software coding
    [||||||||||] 100% - Built
    (Always tweaking!)
    Sep 2006
    Cornwall, England
    Been looking around on ebay for web cams and I saw a few that say...
    --- Automatic brightness adjustment and color compensation ---
    Do you think one of these would give me what I need?
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    (Always tweaking!)
    Nov 2006
    Isle of Orkney. UK
    Auto adjustment should be sufficient. It should work.
    But what is more important is the angle of view. I think that the normal web cam is too narrow. Also does it have to be USB ?
    I bought a wide angle (108 degree) car reversing camera off the bay. It is surrounded by
    10 LED's. It cost 1p with £12. 99p postage. They are still advertised at that. I wasn't expecting much for that but is brilliant. It will flare if sun hits the lens directly, it is colour during the day and switches to mono at night with the infra-red. Thoroughly recommend it
    Sep 2006
    Cornwall, England
    I was thinking of mounting it facing down where the back door handle is so I can see the rear bumper at the bottom of the screen and whatever is behind the van at the top.
    I'll check out the camera you are talking about
    cheers
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    (Always tweaking!)
    Sep 2006
    Cornwall, England
    I've looked at some cameras, but they are all composite outputs and I'm using a VoomPC 2 enclosure with a VIA cn700 motherboard. This doesn't have 'composite in', so I think I'll have to use a webcam, unless I can get a composite to USB device.
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    (Always tweaking!)
    Nov 2006
    Isle of Orkney. UK
    What screen are you using? I got mine from CarTFT. It has separate inputs and also reverses the picture. The camera is wired directly to it
    Sep 2006
    Cornwall, England
    I have the Lilliput 2008 model. It has direct input on it, but I would like to software code it so my front-end automatically switches to the reverse screen, which would still allow me to use the volume and other features in the front-end.
    I have emailed a few people about various web cams and some of them have auto brightness etc. so I think I will give one a go.
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    (Always tweaking!)
  1. Another Lilliput issue, Maybe
    By djmickyg in forum LCD/Display
    Last Post: 05-04-2008, 05:29 AM
  2. .M3U issue "Play all" issue
    By Kimota in forum StreetDeck
    Last Post: 12-12-2007, 09:34 AM
  3. setting screen brightness and contrast permanently
    By G35Pimp in forum LCD/Display
    Last Post: 07-27-2007, 08:54 PM
  4. Boot issue
    By Slippin3 in forum Power Supplies
    Last Post: 02-07-2006, 01:19 PM
  5. Brightness Console 1.0
    By OvernightTech in forum Software & Software Development
    Last Post: 02-14-2004, 07:19 PM
