wow.. looks great arby... Maybe i should just embed this into rr skin as a default music skin and take advantage of all the winamp built in function...
Here you go guys, finally got everything figured out.
DOWNLOAD: www.arbybean.com/skin/ArbyFullscreenWA5.wal
Drop the file into your winamp\skins directory.
Still to do:
- Add equalizer
- Add minimized mode
- Add more color themes
- Add day/night color theme switcher
Things you should know:
- There are some custom options under the options menu. These enable and disable different parts of the skin.
- If you have multiple windows open when you first load the skin, it will act wonky. Switch through each of the layouts and it should be back to normal.
- When the titlebar is visible, the skin can be moved around and resized. When the titlebar is hidden, the skin is locked in place.
- I developed this with winamp 5.52. If that's not what you're using, it might break.
Let me know what you like and what you don't. If you make any cool custom color themes, post them and I can add them in.
Enjoy!
:music:
Arby, you're my hero...
very very very good skin! spent a day to find it! It matches all my needs.but one little issue - minimize isn't working.
It's on the todo list up there. ^
Should have a newer version out next week.![]()
Really great work! Is is possible to make the fonts of the playlist bigger in the next release?
I believe you can control the font size in the WinAMP preferences.
Correct. You can change the font size in the playlist section of the preferences.
sorry for my blindness![]()
Damn, just got around to downloading this. This skin is off da hook! I'm using it now.
