Results 1 to 6 of 6
Thread: auto rip?
    May 2000
    Ft Gordon, GA
    auto rip?
    here is my delema of the day. i want to be able to put a cd in the drive and have it automatically rip it to my hard drive if it does not already exist. is there software out there that makes this possible? thanks,
    Etrik
    "if everything is under control, you're not going fast enough!"
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Here's a start...
    You can specify the program to run when an audio cd is inserted by changing the following registry key:
    [HKEY_CLASSES_ROOT\AudioCD\Shell\Play\Command]
    Got this from here: http://www.winguides.com/registry/display.php/859/
    Have it run a batch file or some custom program that will detect if the cd has been ripped yet. (possibly use CDDB for song title lookups)
    I'll bet there are command-line rippers out there... (I know there are many command line encoders!)
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    how are you going to keep order of the cd's? if you aint got a internet connection that is.. cdtrack1 cdtrack2 and so on
    May 2000
    Ft Gordon, GA
    right now i use mmjb (dont laugh) and have it look at my local ccdb (downloaded from freedb) when im on the road and ripping (like at a friends house). but i want to be able to just pop the cd in and have it rip away as im getting rid of my tft and wont be able to see to start the process. thanks for the info patO, i will look into the commandline encoders. any more ideas?
    Dec 2002
    East Tennessee
    I'll have to try that for ripping CD's. It looks a lot easier then hacking the old 3-watt cell phone I have installed in my car to get to the CDDB. Now all I need is a command line ripper/encoder that works like audiocat....
    Comp. Specs:Shuttle SS40G, Athlon XP 1700+, 256MB DDR, 40GB HD, Belkin Desktop 802.11b card (good range), SB 128 sound (onboard is a bit noisy), DVD ROM
    Toshiba 100CS laptop, P75 40mb ram, 550MB HD, Megahertz LAN/modem PC card, modified to run off 12VDC
    Other stuff:Generic USB hub & USB to serial adapters, BS2SX power control system w/battery buffer, Jazz 300W Inverter, FM Modulator, Palm Vx, & GPS
    Status: 80% complete (Almost done with the controle boxes)
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    etrick, how large is the db? Does it work well?
    I have been looking for a solution like this (it is a zen kind of search ;-))
    TruckinMP3
    TruckinMP3
    Read the FAQ!
