Results 1 to 7 of 7
Thread: boot windws screen
    Mar 2008
    boot windws screen
    how can disable windows boot screen ?? i want to open the pc and go to the centrafuse without appear boot windows boot screen ??
    Elsewhere
    There are utilities to change that boot screen to something else.
    However, you're altering cvore files for Windoze and may render your OS unusable. Personally, I don't mess with them, but others have changed their boot screens with success.
    Good luck.
    How about the Wiki?
    Constant Bitrate toyotatyrant's Avatar
    Aug 2007
    Hampton Roads VA
    If you are trying to do what I think you are trying to do, then it's pretty easy in windows xp.
    1. in windows press the window key or click "start" to bring up the start menu.
    2. Next select "run" from the start menu. which will open a command line window.
    3. Type "msconfig" on the command line and press ok.
    4. The system configuration utility will open, and you will need to click the tab that says BOOT.INI.
    5. Now under "boot options" check the box that says "/NOGUIBOOT" then press apply and ok.
    This is the safe way turn off that tacky windows boot-up screen.
    Mar 2008
    Smile
    Quote Originally Posted by toyotatyrant View Post
    thanks my friend this is that i was trying !!!!
    Apr 2008
    Dubbo, Australia
    does this increase the speed of the startup??
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by AaronG85 View Post
    Slightly.
    But you'll still get a black screen until it finishes it's boot.
    I just replaced mine with my car logo in a startup screen.
    Tune up utilities 2008, stardock, etc are some of the utilities that change it with minimal fuss for the "less adept" users..............
    Leonardo Da Vinci
    Aug 2007
    Hampton Roads VA
    Quote Originally Posted by kostas_lion View Post
    No problem brotha, glad to be of assistance.
  1. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  2. Replies: 1
    Last Post: 06-23-2007, 01:25 PM
  3. any feedback info. on Dynamix 7" VGA Touch Screen TFT ???
    By xtreamvette in forum LCD/Display
    Last Post: 04-22-2007, 04:19 PM
  4. Boot Screen etc
    By World705 in forum WinNT Based
    Last Post: 06-22-2006, 11:12 AM
  5. Simple custom boot screen. no 3rd party software!
    By knubile in forum WinNT Based
    Last Post: 06-15-2005, 09:54 PM
