Yes I get the same error too. I suspect that Amazon has changed its interface (URL or search results HTML) so the parsing of the downloader program won't work anymore. You may want to try disabling the "Amazon" search and use the others instead.
i downloaded album cover art downloader yesterday and it was working perfect for me! i was able to do about 40 albums without any problems. but today, i started having a problem with it. ive reinstalled it several times, and it doesnt work. it used to work before. now its poppin up this error and i cant download the images. but i can drag and drop images i find from online. any help?
Downloading cover images was interrupted by the following exception:
Expat Error: not well-formated (invalid token): line 4, column 11
more information:
Traceback (most recent call last):
File "F:\cygwin\home\Sami\proj\albumart\dist\installer\ buildalbumart-qt-w32\out1.pyz/process", line 63, in run
File "F:\cygwin\home\Sami\proj\albumart\dist\installer\ buildalbumart-qt-w32\out1.pyz/albumart", line 115, in getAvailableCovers
File "F:\cygwin\home\Sami\proj\albumart\dist\installer\ buildalbumart-qt-w32\out1.pyz/albumart_source_amazon", line 48, in findAlbum
File "F:\cygwin\home\Sami\proj\albumart\dist\installer\ buildalbumart-qt-w32\out1.pyz/amazon", line 315, in searchByKeyword
File "F:\cygwin\home\Sami\proj\albumart\dist\installer\ buildalbumart-qt-w32\out1.pyz/amazon", line 293, in search
File "F:\cygwin\home\Sami\proj\albumart\dist\installer\ buildalbumart-qt-w32\out1.pyz/xml.dom.minidom", line 1919, in parse
File "F:\cygwin\home\Sami\proj\albumart\dist\installer\ buildalbumart-qt-w32\out1.pyz/xml.dom.expatbuilder", line 928, in parse
File "F:\cygwin\home\Sami\proj\albumart\dist\installer\ buildalbumart-qt-w32\out1.pyz/xml.dom.expatbuilder", line 207, in parseFile
ExpatError: not well-formed (invalid token): line 4, column 11
why would it show that error though? wouldnt it just not show amazon's results? odd...but yea..i just tried that and now it works..thanks!
actually..it just kind of works. it doesnt show much results like it used to. also..funny thing is..if i use this program..it searches wal-mart and sometimes it doesnt show any results. but yet, if i were to go to their site and manual search, i get results..odd
also..it seems that the search takes longer =( i wonder if theres a way to really fix fix it
okay...i just got an email from the guy. so yea..just disable the amazon one and it should work fine. just slower and maybe less results
Unfortunately starting this April, Amazon has deprecated their old
web service which was used to download the images. At this time, the
only work-around for this error is to therefore disable the Amazon
image source from the program settings.
Please see http://unrealvoodoo.org/hiteck/projects/albumart/ for
further information.
