Results 1 to 2 of 2
Thread: RockCar Skin Preview
    Constant Bitrate Hessian's Avatar
    May 2007
    This is what I have so far for a new default skin for the RockCar C# front end. The buttons are bigger than 70x70 and should be easy to hit. The contrast should look good in the sun as well.
    Any suggestions?
    I'm close to getting the MapPoint GPS plugin working. I've had lots of issues with getting the GPS to track correctly. Is there a better C# GPS approch, maybe something other than MapPoint?
    May 2007
    GPS Working
    I got the MapPoint plugin tracking my location now. Because the API really has no good GPS hooks while using the Active X control, I had to go about this in a different approach.
    As part of adding GPS; location and speed information are now available to use in the skins.
    I've been working on including album art in the screen where you select the media. The screen shot below was taken using the old skin.
    Still working on the new skin, just a matter of skinning the image after I work out the above kinks.
    I also removed the wavLib library that was causing issues in 64bit. Although I've not tested in 64 bit yet.
  1. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  2. CENTouch (Skin Preview) [dialup beware)
    By house98 in forum CF Skins
    Last Post: 11-12-2007, 10:44 AM
  3. Simple Skin Preview
    By arise360 in forum FrodoPlayer
    Last Post: 01-03-2005, 11:35 PM
  4. skin preview
    By liquid_smoke in forum ME Archive
    Last Post: 12-16-2003, 09:48 PM
