MPXF spectrum configurable?
Is it possible to create a 5 wide by 2 high spectrum doobry on MPXf? I love the UI of it - the menu system fits perfectly on a 4x20 and is very handy, I just want the menu system available but when playing the mp3s I want the screen to show a small spectrum graphic and the vitals - name/band/album/times.
Using a winamp plugin I got the configuration I wanted, but I want it from DOS. All I want to know is whether or not its possible, not how to do it - save y'awl the hastle I'll put the effort in myself once i know its a do-able thing.
Cheers,
James
Its a long time since I played with the setup of MPXF.
I think if you look in the MPXFTSR.CFG file, look for the switch/lines
; %eXX - Display equalizer on 1 line. (XX is range 00-28)
; %eqX - Display equalizer on 2 lines. X is 1 or 2.
; %eNL - Display EQ on N lines, where L is the current line
That may do what you want.
cool, yep, my eyes didnt spot that - cheers for the pointer.
James - just waiting for his lcd to arrive - I sense it may be some time from eio - they arent the most prompt of suppliers it seems
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
