Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Making dashcam application with speed overlay.
    May 2006
    Calgary, Alberta
    Highly influenced by this thread, I'm writing an application that will record out your front window while the computer is running and overlay the speed onto the video. You might ask why since there's already RRcam but that isn't standalone and has to be embedded into a skin from what I read. So I'm writing this one independent of RoadRunner or any front end. Currently I'm using the Java Media Framework (JMF) to capture images at a specified framerate and save them in sequence. Then run another file and it merges all the images into a .mov file and plays as a video. All I've got to add is the NMEA parsing from the GPS receiver and the overlay of the text. This thread is just to let you know the progress.
    For any questions about my Java front end, it's on pause. Lots of issues with the seek bar.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    since it's java, are you keeping cross-platformability in mind?
    Also, why the mov format?
    I like the idea btw . How will it interface with the gps device?
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    May 2008
    Any estimations on the amount of CPU power required to complete these tasks? It sounds like it might be quite a ressource hog...
    May 2006
    Calgary, Alberta
    Cross platform will likely be possible, but I'll need to resource a machine to test it on. I simply have to have a check for the 2 different types of camera drivers for each platform.
    .mov right now is just what was in the piece of software I hacked up from forums.sun.com but I'm thinking about converting it to .mpeg or .asf. I'm not sure though, I don't really see a need to. I won't be reviewing the tape very often and if I need to, I can convert the finished video later.
    It'll interface with the GPS only to pull the NMEA sentence and then parse the sentence once it has it. You'll be able to get all GPS information from this single string such as heading, speed, location, altitude, all that stuff.
    And sorry, no estimates on CPU power right now, going to have to wait until it's done to see how it performs! I got the recording almost done now, just got to work on the NMEA catching/parsing.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    will it be open source?
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    If you can get this working to auto record and not error on standby/resume I will be very interested.
    Apr 2008
    Baghdad, Iraq/Fort Bragg, NC/Saginaw, MI
    I've put together a fairly reliable NMEA parsing app, but it has a bit of overhead, due to having to hold my serial controller's hand... the Serial controller that came with my GPS likes to blue screen windows, if you try to read data as soon as its dropped in the buffer... for some reason, it like the data to sit in the buffer for atleast 100ms... I havn't been able to figure out a good way around it, other than manually "aging" the data in the buffer, and checking to see if the data is atleast 100ms old before polling the buffer.
    but in any sense; for most of my resources, I used:
    http://www.gpsinformation.org/dale/nmea.htm
    about 90% of the info in there is accurate. I can't speak for Java, but in Visual Basic, parsing the info was very easy. Only thing to remember, is the lat and lng that you get from GGA, RMC, and GLL are not in a "standard" format..
    When you are done with the NMEA parsing function, I'd love to see how you managed the logic, on a per-command basis!
    thanks
    Mike
    May 2006
    Calgary, Alberta
    Quote Originally Posted by kev000 View Post
    yes
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Variable Bitrate eric_barcus's Avatar
    Mar 2007
    watching this closely if you need a beta tester im all yours
    May 2006
    Calgary, Alberta
    haha thanks! I took a look at the J3D application from SUN last night and it's very interesting. It caches a frame from the video and then compares every pixel to all the pixels in the next frame. If any pixel has changed to a predefined degree, the frame is said to have changed and therefore detects movement. It's a motion detection application purely written in Java and it works great. I just don't know if I need to incorporate it since this camera will probably record all the time the car is moving. There'd be no point in having it not record if the computer is on. It'd be useful in a home security project though.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 10:27 AM
  2. Replies: 0
    Last Post: 09-23-2006, 08:38 PM
  3. Replies: 2
    Last Post: 05-02-2006, 01:14 AM
  4. Replies: 2
    Last Post: 08-31-2005, 06:01 PM
  5. Article: spy device will cut driversí speed by satellite
    By VanMan69 in forum General MP3Car Discussion
    Last Post: 08-06-2005, 09:22 AM
