Very nice - have you got any instructions on how to do this? Like; where do you get the binary from?
Dan
Thought I'd throw this info out for anyone who wants to see anything cool.
Canola, is a media application designed for the nokia n800. It manages things like podcasts, video, music, and pictures. I looks good.
I downloaded the binary (no source, it's closed) and got it running under LinuxICE. Below are some screen shots and a youtube video of it running on the n800.
NOTE: I will not be including canola within LinuxICE because canola is not free (as in speach). It would break LinuxICE's GPL license if I did. That doesn't stop anyone from using it though
[media]http://youtube.com/watch?v=8RKHvM7sOU8[/media]
Linux - "People just give you stuff. ...And it's good"
Former author of LinuxICE, nghost.
Current author of nobdy.
Dan
It was pretty easy, I took some notes when i did it. I downloaded the binary from canola's website. Here are the deps that I installed on top of a stock LinuxICE build:
libXcomposite
libxp6
After that, it just runs.
Thanks for the info; unfortunately I am not having the same success. I have those two dependencies installed, but I am getting the following;
What I have done so far is downloaded the deb file. Then extracted the binary;Code:dan@ux1xn:/$ canola Traceback (most recent call last): File "/usr/bin/canola", line 18, in <module> import ecore ImportError: No module named ecore Error in sys.excepthook: Traceback (most recent call last): File "/usr/lib/python2.5/site-packages/apport_python_hook.py", line 38, in apport_excepthook from apport.packaging_impl import impl as packaging File "/usr/lib/python2.5/site-packages/apport/__init__.py", line 1, in <module> from apport.report import Report File "/usr/lib/python2.5/site-packages/apport/report.py", line 17, in <module> import xml.dom, xml.dom.minidom File "/usr/lib/python2.5/site-packages/PIL/__init__.py", line 220, in <module> ImportError: cannot import name DOMImplementation Original exception was: Traceback (most recent call last): File "/usr/bin/canola", line 18, in <module> import ecore ImportError: No module named ecore dan@ux1xn:/$
I have then extracted all the files in data.tar.gz into the correct places.Code:ar -x canola2_2.0.0~beta9-maemo1_all.deb
Were there any other Maemo .debs you had to extract before this worked?
Thanks again
Dan
I should have said before, and I apologize, that I got it in a precompiled tarball from here:
http://openbossa.indt.org/canola/sou...-beta9.tar.bz2
I didn't use the maemo package.
check out: http://openbossa.indt.org/canola/developer.html for more info.
cheers.
Hi Kev,
I'm not sure if you have already done this yet, but I have been trying to get some plugins working with Canola on the desktop. Specifically the Youtube and Last.FM plugins. I have been successful, so I thought I would add to your post with how to get the plugins working. It may be useful to someone, so here's how I did it:
first make a tmp directory
Download the relevant Maemo package for the addon you want to install from here. http://repository.maemo.org/extras/pool/gregale/free/c/Code:mkdir /tmp/cnl_plugins cd /tmp/cnl_plugins
as an example; this is how to do the youtube plugin;
Now you need to extract that package (as it's designed for Maemo, not a desktop distro you can't just install it).Code:wget http://repository.maemo.org/extras/pool/gregale/free/c/canola-youtube-plugin/canola2-youtube-plugin_0.1.3-maemo1_all.deb
This extracts two files; control.tar.gz and data.tar.gz. In a nutshell; the control file contains the distribution specific installation instructions and the data file contains the compiled files.Code:ar x canola2-youtube-plugin_0.1.3-maemo1_all.deb
With that in mind it's fair to say we can dismiss the control.tar.gz file as we are not installing this on Maemo. So we need to extract the data from data.tar.gz;
Code:tar xvzf data.tar.gzNow that all the files are in the correct place, all we need to do is get Canola to *look* for the new plugins. For that please do the following;Code:cp ./usr/share/canola/themes/* /pathtocanola/canola/THEMES/. --recursive --preserve cp ./usr/share/canola/themes/* /pathtocanola/canola/data/themes/. --recursive --preserve cp ./usr/share/canola/plugins/canola-tube.zip /pathtocanola/canola/plugins/. --preserve
Now when you run Canola you should see the plugin present.Code:dan@ux1xn:canola$ ./run-canola.sh --shell -------------------------------------------------------------- Assuming installation path as '$canola_path'. If that's not right you should edit the BASEPATH var in this script. -------------------------------------------------------------- Configuring environment... root@ux1xn:canola# bin/cnl-rescan-collections root@ux1xn:canola# exit
I have tried this with a different theme as well as the youtube and lastfm plugins. There is an issue with the last fm plugin. It installs fine, but won't make outbound connections to the Internet for some reason. Just guessing, but I think this may be due to Canola monitoring the status of WLAN0 (the card identifier on the Internet tablets), and my UX1XN has ATH0 instead. Youtube stuff works fine though... I'm working on getting lastFM working.
Hope that's useful to someone; any questions give me a shout!.
