Docking WinAmp Visualizations in your frontend
I am working on a frontend for winamp(Yes I know who isn't) But there are specfic things that I like, that I have not seen in other packages. Anyways, I have seen several people do it with some of their frontends... How do you get a WinAmp Visualization inside your program??? Are you just making transparent windows, with the Vis behind it?
Thanks,
Quincy
Or putting the vis on top.
But most Visualizations have Borders and Title Bars around the windows....
Ah yes you're probably right but i thought you were referring to autoplay which uses the sexy attached analyzers plugin that goes on top of the form and doesn't have a title bar.
exactly..... I also used to use AVS, and made a winamp skin with all black around the AVS gfx skin bits...
but AVS seemed to be really buggy with w98 (at least for me) so I ditched it for Sexy Atached..... sadly milkdrop/etc dont have an option for no borders...
there might be a way with the winamp API, where u can control a window and then change its borders that way?? might be something I look into as well..
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
