Results 1 to 5 of 5
Thread: Usb 2.0
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Virginia
    Usb 2.0
    I have an VIA EPIA SP motherboard. I have one USB 2.0 device, my 802.11G wifi device. It worked on my initial installation of WinXP SP2, however after a reformat/reinstall of WinXP SP3, upon installation of the device, i get a "this device could be running faster" message and the device never detects. The thing is i have USB 2.0 ports. i plugged it into the same port i used before, i even tried every other port on the board. i also installed USBInfo to see if i had any 2.0 ports and i don't.
    Do i have to use a different driver to get USB 2.0?
    Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    if you're absolutely sure you had USB 2.0 before your reinstall, do the following:
    Go through the BIOS and make sure all USB is turned on and, if configurable, set to 2.0.
    Some of your ports might be USB and others USB 2.0. The manual may provide some insight here.
    Find the latest Via USB or 4in1 drivers for your board. Most likely through via.com.tw, or viaarena.com. Looks like the Via Epia SP series drivers are at http://via.com.tw/en/products/mainbo...erboard_id=261
    Jun 2004
    Virginia
    thanks, i actually installed them, but they did not detect as new devices. is there a way to Update Drivers and select a new driver? if so, what do are they called? Are they Microsoft or Via drivers? are they the Enhanced PCI to USB drivers?
    Jan 2006
    uninstall the drivers in cpl / system / hardware... there are lots of them..
    just uninstall them, reboot, go to bios, make sure escd is on for usb,
    then load windows. let them auto detect.
    Nov 2007
    I'm also guessing it's a driver issue. I'd try the device manufacturer, see if they have a more recent driver that you can download.
  1. Overpowering USB 2.0 Cardbus card
    By freudie1 in forum Power Supplies
    Last Post: 11-30-2006, 10:51 AM
  2. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  3. IDE to USB 2.0 converter
    By goosef350 in forum General Hardware Discussion
    Last Post: 08-11-2005, 09:29 PM
  4. USB 2.0 on Win2k3...need service pack?
    By Grayscale in forum Software & Software Development
    Last Post: 08-21-2004, 03:49 PM
  5. USB 2.0 drivers without SP1 WINXP
    By videodok in forum Software & Software Development
    Last Post: 12-11-2003, 08:04 AM
