Results 1 to 3 of 3
Thread: A few questions about drivers...
    _
    Mar 2004
    Little Elm, Texas
    A little background:
    I'm running some amplifiers that have built in monitoring capabilities.
    Things like a digital serial number, voltage meters, temp sensors, fan control, etc.
    The thing is, it's kind of like a beta thing from this company. At one point in time I had some drivers that worked. Then I formatted my hard drive and got new drivers...but they don't work.
    I'm wondering if anyone on here knows how to write drivers....I'm sure someone does.
    And if that someone might be willing to take a look to see if they can get these things to work?
    My only question is...do you have to have access to the hardware at the same time to do this?
    The amplifiers have RJ-11 ports on them, there is a hub that has a bunch of RJ-11 ports on it to plug the amplifiers into. This hub then plugs into a computer via USB.
    Jan Bennett
    Vendor - Qube colin's Avatar
    Dec 2006
    Typically you'd either need the hardware or a definite protocol.
    Even then it would be untested, because a lot of times when you THINK your protocol works perfectly, youll get an unexpected response and it'll mess your whole program up.
    Or maybe that's just me and Im a bad programmer? But I think my work is pretty high-standard...
    _
    Mar 2004
    Little Elm, Texas
    That's what I'm figuring.
    I might just have to contact the company directly in Italy for these...and beg and plead with them to give me a working driver.
    Jan Bennett
  1. Intel 865 custom drivers
    By neilwozau in forum LCD/Display
    Last Post: 07-02-2010, 12:52 PM
  2. Questions about kx project
    By hornyleprechaun in forum Car Audio
    Last Post: 06-20-2006, 04:55 PM
  3. Replies: 8
    Last Post: 05-21-2006, 04:00 AM
  4. Drivers for a NON touchscreen Lilliput?
    By romeov in forum LCD/Display
    Last Post: 07-20-2005, 05:19 AM
  5. Audio setup questions/ KX Live drivers
    By Mahamoti in forum General Hardware Discussion
    Last Post: 02-05-2004, 02:01 PM
