Results 1 to 9 of 9
Thread: Small screen simulator
    Feb 2007
    I remember a while back there was a program mentioned here that simulated a 7" screen on a desktop monitor,so you could see what a program would look like on a small screen while working on a desktop monitor, it didnt just resize monitor screen,showed 7" screen as it would really look like,hope i made sense with the description! Anyway i cannot find it now,i was hopping someone can remember it and has a link. thanks all
    Apr 2007
    Seattle
    If you can turn off scaling in your video card drivers and set your res appropriately you can get the same effect.
    CwF
    CwF is offline
    Jun 2008
    Denver(ish)
    If you have some computers laying around, use one to work on the software, set the display to what you'll really use, and VNC into that box from your desktop at that resoltion, and then scale to the real size. Nice to do on a higher res desktop.
    06 Silverado LBZ wants onboard everything...
    Feb 2007
    Vnc ??
    CwF
    CwF is offline
    Jun 2008
    Denver(ish)
    remote desktop software. VNC is the original and a few freeware versions out there.
    http://www.realvnc.com/
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    why not try vmware and set the resolution in that.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    CwF
    CwF is offline
    Jun 2008
    Denver(ish)
    Maybe it simply depends on what question we're answering. With VNC you have the actual hardware and with a vmware solution you don't. If the purpose is to develop the software, vmware may be a solution, but, the VNC method would eliminate unknowns since it is running on the actual hardware to be used.
    Apr 2005
    Fresno, CA
    Well the first post was that he wanted to know what it would look like on a 7 inch monitor. Both VNC and vmware don't really give you that. But i did install vmware 6 to see what it would look like. It does seem if you set the max resolution to the same as your carputer screen (7inchs) you get a good idead of what it will look like at that resolution and possibly screen size.
    Also the RRSkinEditor can zoom in/out so if you just wanted to see it smaller that may help too, only for RR Skins.
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
    Feb 2007
    Thanks all for the help, i shall find vmware 6 and have a play, i recall the prog. i was thinking of showed a screen in the middle of the monitor just as the (in my case)7" monitor woul look like, it was a couple of years ago when i was digesting the possibilities of a carputer
  1. FAQ: Touchscreens explained
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 07-21-2008, 11:10 AM
  2. Small screen friendly skin
    By navmaxlp in forum RR Skins
    Last Post: 02-24-2008, 08:06 PM
  3. lcd screen: as small as i can go...
    By HeLLz aNgeL in forum LCD/Display
    Last Post: 09-01-2007, 04:54 AM
  4. MP3 player with big buttons for small screen?
    By sargatlarge in forum General MP3Car Discussion
    Last Post: 09-22-2005, 12:36 PM
  5. Small screen, similar to PS-One
    By frodobaggins in forum LCD/Display
    Last Post: 05-22-2003, 01:53 AM
