Results 1 to 2 of 2
Thread: Disable/Remove Intel Management Engine?
    _
    Mar 2004
    Little Elm, Texas
    Does anyone know how to remove this feature from a motherboards BIOS?
    I would like to find a way to prevent it from telling you to press CTRL + P during boot up as I'm looking for ways to speed up boot and this is one of the last things I need to get rid of.
    Anyone?
    Jan Bennett
    Constant Bitrate b3tts32's Avatar
    May 2006
    Arlington, Tx
    That sounds like pxe is enabled or a boot to nic option to me. I'd see about checking into those either under nic options or boot options in the bios.
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  2. Intel D201GLY BIOS Petition, Mobo selection (C2D?) and test results!
    By Lope in forum General Hardware Discussion
    Last Post: 09-02-2008, 07:55 PM
  3. Wiring backup/Rearview camera -- can engine crank damage?!
    By justintime in forum General Hardware Discussion
    Last Post: 03-03-2008, 04:55 AM
  4. Replies: 23
    Last Post: 03-01-2007, 05:37 PM
  5. How is this motherboard? Intel board inside..
    By sspiro in forum General Hardware Discussion
    Last Post: 01-16-2005, 02:16 PM
