Hi!
I have an self slipstreamed version of XP Pro SP3 (Norwegian), with IE7 and WMP11.
Installed this on the harddrive on a laptop (meant for carputer use), optimized it and installed EWF and HORM (working fine), then I cloned it over on an CF card and installed it in the laptop, and it booted just fine
But EWF wasn't working, but figured it out and fixed it.
So it works now
But have a wierd problem..
If the laptop is running on ac adapter and is not used for some minutes, it goes in hibernation
And if I run it on battery it works just fine (don't go in hibernation)
Have checked power settings in windows, and they are correct, (set to never put it in hibernation unless I want it..)
Anybody else have this problem? Or knows how to solve it??
PS, I havn't testet it from the harddrive to se if the problem is there to..
