Results 11 to 20 of 25
Thread: Vista 64 bit driver problem
  1. #11
    Variable Bitrate Bigseven74's Avatar
    Jan 2008
    2.5 vista ultimate---- about to dual boot the laptop
    2.5 xp pro------------
    1 windows 3.11 in the garage
    1 dos 3.1 unopen in box (nib)
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Bigseven74 View Post
    You have a NIB 3.1?! Jealous...
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Jan 2008
    lol yeah i couldnt believe it when i found it.
  4. #14
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Why not just get a certified serial to usb adaptor?
    I'm running vista 64 on my quad core phenom build and it smokes the 32 bit OS's running 32 or 64 bit software.
  5. #15
    Jan 2008
    Dynex has discontinued the one i have even if you by the newly designed one, u still run into the same problem.
    even belkin site has stated that "There is currently no driver for Vista 64-bits."
    what are you running?
    read post 3
  6. #16
    May 2008
    Looks like it's a PL-2303 usb-serial chip. I found some Vista drivers here but I have no idea if they will work for you.
  7. #17
    Jan 2008
    update on dual booting
    didnt work.
    xp keeps crashing in the loadscreen.
    I even tried to youtube it and i was doing everything right but it just continue to crash on me.
  8. #18
    Jan 2008
    back to the drivers
    vista 32 will unoffically work the drivers, but 64 is a different beast but i will give a try
  9. #19
    Jan 2008
    i couldnt find where files where extracting to so i made windows search still no luck with the drivers
  10. #20
    Jan 2008
    is there another way to dual boot with vista perinstalled?
  1. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 11:52 AM
  2. Vista Ready board does not see XP only peripherals
    By jdiazj1 in forum General Hardware Discussion
    Last Post: 06-05-2007, 10:57 PM
  3. New driver required for Vista?
    By kiarash in forum LCD/Display
    Last Post: 03-09-2007, 07:20 AM
  4. Core Duo/Core 2 Duo processors
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 02-06-2007, 09:00 PM
  5. Questions!
    By Yellow-Snow in forum Mobile Impact
    Last Post: 06-10-2006, 06:18 PM
