Results 1 to 5 of 5
Thread: GPS subtitle recorder - CarPCSub
    Apr 2006
    Greensboro, NC
    CarPCSub Version 0.1 [email protected]
    CarPCSub is a small command line utility I have written that functions as a GPS to subtitle recorder. This application is written in Perl and the source is available. The .exe file included is compiled to run on a Win32 OS. This utility records GPS NMEA data via a communications port to a video subtitle file. This application can write SubRip .srt or Advanced Sub Station Alpha .*** files. This script is intended to be ran along side video recording software in a CarPC (Carputer) with the intent to later play back or encode (overlay) the GPS position, time, date, speed, etc. with the video. This script could be ported to Linux using Device::SerialPort. This application will not work with the XPort communications port sharing application. CarPCSub Version 0.1 is released under the open source GPL license. Please share this application. If you find this utility use full please send me a message and let me know.
    You can download this utility at the following link:
    http://www.geocities.com/carpcsub/CarPCSub01.zip
    GarGoil
    VIA Epia M10000 MB
    512 DDR RAM
    40G 2.5 HDD
    M2-ATX
    SP7 7" VGA TS dash
    Lilliput 7" RCA rear
    Holux GM-210 GPS
    Linksys WUSB54G
    Mini-Key USB KB
    CarPCSub 0.71 Win32 + 0.71L Linux
    GPS to Subtitles Recorder
    http://carpcsub.sourceforge.net
    Dec 2006
    India
    Interesting idea...But I'm a little confused...
    How do you synchronize the recorded video and the GPS subtitle?...
    Is there a recording application that can start the video recording and the script at the same time?
    Apr 2006
    Greensboro, NC
    GPS to Subtitles CarPCSub
    DigitalVampire,
    At this time, I launch both the CarPCSub recorder and the video capture VLC VideoLAN Media Player from .BAT batch files. It would not be hard at all to issue a system() or an exec() command to launch the video player when the CarPCSub recorder starts. I will have to add this feature! In theory, we could launch any video recording software that would accept input from the command line (e.g. VLC).
    Thank you very much,
    GarGoil
    VIA Epia M10000 MB
    512 DDR RAM
    40G 2.5 HDD
    M2-ATX
    SP7 7" VGA TS dash
    Holux GM-210 GPS
    Linksys WUSB54G
    Mini-Key USB KB
    Apr 2006
    Greensboro, NC
    GPS to Subtitle Recorder CarPCSub
    CarPCSub Version 0.5
    This utility records GPS NMEA data via a communications port to a video subtitle file. This application can write SubRip .srt or Advanced Sub Station Alpha .*** files. This application can also write .csv comma separated values files. This application is intended to be ran along side video recording software in a CarPC (Carputer) with the intent to play back or encode the GPS position, time, date, speed, etc. with the video. This utility will attempt to launch VideoLan Client Media Player and record a DIVX video from your default video input device. You will have to download VLC Media Player separately.
    CarPCSubGUI Version 0.5
    CarPCSubGUI is a Graphical User Interface for the CarPCSub command line utility. This application is written in Perl and the source is available. This GUI executable is compiled to run on a Win32 OS.
    Screen Shot of CarPCSubGUI
    [media]http://209.190.85.46/CarPCSubGUI.png[/media]
    http://carpcsub.myownfreeweb.com/
    GarGoil
    VIA Epia M10000 MB
    512 DDR RAM
    40G 2.5 HDD
    M2-ATX
    SP7 7" VGA TS dash
    Holux GM-210 GPS
    Linksys WUSB54G
    Mini-Key USB KB
    Apr 2006
    Greensboro, NC
    CarPCSub 0.71L Linux GPS to Subtitle Recorder
    Hello,
    CarPCSub 0.71L a Linux x86 build has been release. This project is hosted on http://sourceforge.net/projects/carpcsub/ and at http://carpcsub.myownfreeweb.com This application uses VideoLAN Media Player to record videos and the CarPCSub utility to record your GPS as a subtitles file for later play back or encoding.
    Thank you,
    GarGoil434
    VIA Epia M10000 MB
    512 DDR RAM
    40G 2.5 HDD
    M2-ATX
    SP7 7" VGA TS dash
    Holux GM-210 GPS
    Linksys WUSB54G
    Mini-Key USB KB
  1. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 08:29 AM
  2. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 01:24 PM
  3. Replies: 3
    Last Post: 08-10-2007, 04:03 PM
  4. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 01:40 AM
