Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 51
Thread: Is there any inclinometer sw out there?
  1. #31
    Mar 2012
    Quote Originally Posted by pierrotm777 View Post
    Cool,
    That would be cool to have the source of your project for all guys that what to build the project !
    Do you this that an interface in VB.NET or C# would be possible, the goal would be to use your project with Riderunner or another FE.
    I will probably release my source code once I have gotten it to a little more refined state. The only software is a code sketch to run on the Arduino and the interface I have written in Processing. From what I understand, Processing is mainly Java based but the commands and syntax are based on C++. I used it because it is designed to be easier to get started with than most of the more advanced languages. I'm a fast learner so I intend to port it into another more commonly used language as I progress. It shouldn't be too hard to duplicate it in VB.NET or C#. Information on how to connect the Wii Nunchuck accelerometer to an Arduino and the sketch I used to extract the raw data are readily available on the web. Connection is only 4 wires, +5v, GND, Data and Clock..... typical TWI or I2C. I should be able to embed what I currently have into Centrafuse which is what I use for a Front End. It will be a short while before I can continue since unfortunately, my desktop died for some reason yesterday. I am using my CarPC to post this.
  2. #32
  3. #33
  4. #34
    Mar 2012
    .NET libraries exist for connect a Wiiremot with a PC and without anrduino !
    Yes... I am aware of this. The Wiimote can connect to a pc using bluetooth. The problem is that I use the Wii Nunchuck (actually, just the accelerometer inside one) WITHOUT being attached to a Wiimote. The Wiimote does have an accelerometer that can be used but it also has a button that must be pushed to connect it every time. It will not auto-connect. You would also need to use a 12volt to 3 volt adapter for power unless you wanted to keep changing batteries. Programming to use a Wiimote is also a lot more complex. Attaching a Wiimote to a PC allows it to be used like an Air Mouse or 3D Mouse. My source code for the inclinometer interface using a mouse as input is already posted with the demo executable attached to an earlier message. The only real difference from my current version is that it lacks to code to read the serial data from accelerometer/arduino.
  5. #35
    Mar 2009
    I want to say to hold on to the code a charge a few bucks for it. It's been YEARS before anyone had gotten off their *** to actually develop this, you should make a few dollards off of it (like $10-$20 or less), or selling the code for a few bucks more to those that want to develop the base further and expand on it. After some time, maybe a year or two, than you can spread the code freely, which would be nice because I'd imagine like small programming projects, the programmers dissappear and having the code would be nice for making the program compatible in the future when things change like operating systems and such.
    Wonder if using the mouse input would mess things up with Centrafuse. Some of the full screen apps keep audio/gps controls no? Using the touchscreen on those controls while the Inclinometer is running would throw it out of wack, no?
  6. #36
    Mar 2012
    I would actually find it difficult to charge for the software for a couple of reasons. First, I am a big advocate of Open Source. Almost everything I am currently using is Open Source.... Processing, Arduino, Arduino IDE. Secondly, the main motivation for this project is to have this type of functionality in my own CarPC. If I ever put together a custom hardware solution for it, I could see possibly selling that part.
    I've also been thinking about calibration. Since the sensor package will be mounted in a relatively permanant location, there would only be need for an "set and forget" sort of routine. With portable devices such as a phone or tablet, the orientation is nearly always changed from one use to the next. Just like the simple floating ball mechanical inclinometers, once they are mounted and calibrated, that task is done until it is moved to a new location/orientation.
    Hopefully, I will be able to do an in vehicle test this weekend. Right now, my CarPC is in my living room being used to write this. My nice AMD Phenom II x 6 tower is on the fritz, a blown mainboard I suspect.
  7. #37
    Jan 2007
    Quote Originally Posted by XSiveJeff View Post
    Hello again,
    I just put together a very short demo of my software and hardware solution prototype in action. Let me know what you think.
    excuse me for the bad English
    Nice piece of software, very useful, congratulations!
    Why not use the motion sensor present in older gamepad Microsoft SideWinder--Freestyle-Pro-Gamepad or those in the range of sidewider microsoft.
    http://en.wikipedia.org/wiki/Microsoft_SideWinder
    http://www.activewin.com/reviews/har...tyle_pro.shtml
    The Gamepad using a usb interface, I personally tested with your software through a small software joy to mouse and it works great.
    In this way you delete the hardware, which for many is complicated interface using the nunchuck arduino, but with the absolute advantage of being able to make a microsoft-compatible device.
    Just change the read data of your software by mouse joypad, you can change this feature?
    I'm not a programmer, I do not know where to put my hand ...
    thank you
    Scusami per il pessimo inglese
    Bellissimo software, molto utile, complimenti!
    Perchè non utilizzare il sensore di movimento presente nei vecchi gamepad Microsoft-SideWinder-Freestyle-Pro-Gamepad oppure quelli della gamma sidewider della microsoft.
    Il Gamepad utilizza un interfaccia usb, personalmente l'ho testato con il tuo software tramite un piccolo software joy to mouse e funziona alla grande.
    In questa maniera si elimina la parte hardware, che per molti risulta complicata utilizzando l'interfaccia arduino nunchuck, ma con l'assoluto vantaggio di poter sfruttare una periferica compatibile microsoft.
    Basta cambiare la lettura dei dati del tuo software da mouse a joypad, è possibile modificare questa caratteristica?
    Non sono un programmatore, non so dove mettere mano...
  8. #38
    Mar 2012
    Quote Originally Posted by simbau View Post
    There is a Processing library that could be attached to my code to read joystick x and y instead of mouse x and y. The Sidewinder Freestyle Pro is the only device of its type that I can find info on. I know of no other motion sensing joystick that uses a wired USB connection. The big problem there would be cost and availability. Any wireless device would either have to keep using batteries or use a 12 volt power supply adapter and would need a button press for each use to connect.
  9. #39
    Jan 2007
    Exactly the gamepad sidewider seems to be the only usb device with motion sensor (is old but working). On ebay is still some gamepad cheap and worth the risk. Perhaps there is also a gamepad of logitech (of the same period of what microsoft) that has a motion sensor.
    You say that in your source there is the possibility to use a library to read data from usb gamepad ...
    But the data x and y gamepad in what way are read, mouse, I understand that using a ratio based on the screen resolution. Right?
    Esatto il gamepad sidewider sembra essere l'unico dispositivo usb con sensore di movimento (risulta vecchio ma funzionante). Su ebay si trova ancora qualche gamepad a buon prezzo e vale la pena rischiare. Forse esiste anche un gamepad della logitech (dello stesso periodo di quello mocrosoft) che ha un sensore di movimento.
    Affermi che nel tuo source esiste la possibilità di poter utilizzare una libreria per leggere i dati usb di un gamepad...
    Ma i dati x e y del gamepad in che maniera vengono letti, per il mouse mi sembra di capire che utilizzi una proporzione in base alla risoluzione dello schermo. Giusto?
  10. #40
    Mar 2012
    Yes, the mouse version simply uses one half the window height and width to set the inclinometer zero point. For an accelerometer raw output, I use the total output range and the values given when it is level to convert to degrees of rotation. For a motion sensing joystick, I would need to know what its numerical output range was to figure out what value equals what angle of rotation. Since a USB joystick appears as a separate HID device, I would just read it instead of the mouse. If I can find a Freestyle Pro to test with, I may do a re-write for it. I can't justify buying one though.
  1. Road Runner Gestures????
    By Nemisys in forum Road Runner
    Last Post: 08-06-2010, 08:37 AM
  2. Which is a better SW for ODBII?
    By Kranks in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-11-2006, 07:43 AM
  3. Can I still use SW controls with an aftermarket HU?
    By Distorted_Axis in forum Newbie
    Last Post: 02-02-2006, 12:12 PM
  4. Sirius RS232 PC Interface * NEW SW *
    By mitchjs in forum General Hardware Discussion
    Last Post: 01-30-2006, 01:22 PM
  5. Replies: 4
    Last Post: 11-05-2003, 10:42 PM
