Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 51
Thread: Is there any inclinometer sw out there?
  1. #41
    Mar 2009
    Quote Originally Posted by XSiveJeff
    I would actually find it difficult to charge for the software for a couple of reasons. First, I am a big advocate of Open Source. Almost everything I am currently using is Open Source.... Processing, Arduino, Arduino IDE. Secondly, the main motivation for this project is to have this type of functionality in my own CarPC. If I ever put together a custom hardware solution for it, I could see possibly selling that part.
    Gotta give ya props for that. Just would like to see you compensated for you work and effors and see this done, and not see you give up.
    I've also been thinking about calibration. Since the sensor package will be mounted in a relatively permanant location, there would only be need for an "set and forget" sort of routine. With portable devices such as a phone or tablet, the orientation is nearly always changed from one use to the next. Just like the simple floating ball mechanical inclinometers, once they are mounted and calibrated, that task is done until it is moved to a new location/orientation.
    True. I'm just seeing this from the mouse standpoint because that's your similated input. Wondering of the mouse will never be at the same location on the screen when the app is loaded, so it would never be at the same starting point. As with the Wii remote acting as a mouse, and the touchscreen on a carpc also being a mouse, it would throw it out of wack, no? i guess it's one thing if the user just opened up the Inclinometer and left it, but what if the user went to switch to the GPS or chance songs on the CarPC, than went back to the Inclinometer, wouldnt' it be out of calibration at that point?
    Yes, the mouse version simply uses one half the window height and width to set the inclinometer zero point.
    Wouldn't this change for people running different resolutions? And going from a window'd move to full screen?
    For an accelerometer raw output, I use the total output range and the values given when it is level to convert to degrees of rotation. For a motion sensing joystick, I would need to know what its numerical output range was to figure out what value equals what angle of rotation. Since a USB joystick appears as a separate HID device, I would just read it instead of the mouse. If I can find a Freestyle Pro to test with, I may do a re-write for it. I can't justify buying one though.
    I'd say stick with what you want to use, and we'll get what we need to make it work.There's no point making custom software for every hardware that everyone wants to use, that would be endless. Choose what you want and go from there. Maybe use the Wii controller for the cheaper one, and than have the ability to get a more precise, more expensive one for those that want to, but you'll be programming forever if you do it for the 100's of different pieces of hardware that you *could* use.
  2. #42
    Jun 2010
    Just want to say great job, keep going and I will be watching this thread and interested in the outcome!
  3. #43
    Mar 2012
    Still waiting to test it in my vehicle. I mounted the sensor inside the case for an xbox memory card. The alternator in my Montero Sport decided to die on me and I won't have the cash to replace it until my tax return comes in. So far, since I am still using my carpc in the house, I have only done a little more work on the software. I resized it to fit in the plugin area in Centrafuse and managed to remove the windows frame and title bar. Now it plays nice with CF after embedding it as an external application using Apploader. Tonight I will see if it behaves doing a standard embed in CF without Apploader. I'll probably start building the GUI for calibration and vehicle image selection as well. My copy of Photoshop and Illustrator are on my regular desktop PC so I can't do much in the way of graphics until I rebuild the MOBO in it.
    I'm also working on a 2 channel stereo analog VU meter display that reads levels directly from windows so it will work no matter what program you use for A/V display.
  4. #44
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    About an inclinometer with an arduino , you can see this thread !
    http://pccar.ru/showthread.php?t=16718
  5. #45
    Mar 2012
    [QUOTE=pierrotm777;1489780]About an inclinometer with an arduino , you can see this thread !
    Nice find my friend! If I can sort through the russian translations, I can use a lot of the info. They used the same accelerometer that I have just started working with. I will need to read that thread very thoroughly.
    Thanks!
  6. #46
    May 2008
    Bordeaux, France
    I play actually with the source plugin code (iCarDuino.dll by Bersenev) that is in C# !!!
  7. #47
    Mar 2012
    Quote Originally Posted by pierrotm777 View Post
    Do you know where I can get a copy of the source code to play with. I have the .dll but would like the source.
  8. #48
    May 2008
    Bordeaux, France
    Quote Originally Posted by XSiveJeff View Post
    I suppose you need to ask to Bersenev if we can use it's code for RR . This code is actually developed for iCardDS (a RR russian copy).
  9. #49
    May 2008
    Bordeaux, France
    I have asked to Bersenev if he accept to give it's code to the RR community.
    I wait it's answer !
  10. #50
    Mar 2012
    I registered on that site and sent him a PM as well. I've also been playing around with iCar DS. Interesting front end. It is fast but I find it a little confusing. If Frankenstein made a CarPC front end, it would probably look like iCarDS, made from pieces and parts that don't really match each other. I preferr more continuity.
  1. Road Runner Gestures????
    By Nemisys in forum Road Runner
    Last Post: 08-06-2010, 08:37 AM
  2. Which is a better SW for ODBII?
    By Kranks in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-11-2006, 07:43 AM
  3. Can I still use SW controls with an aftermarket HU?
    By Distorted_Axis in forum Newbie
    Last Post: 02-02-2006, 12:12 PM
  4. Sirius RS232 PC Interface * NEW SW *
    By mitchjs in forum General Hardware Discussion
    Last Post: 01-30-2006, 01:22 PM
  5. Replies: 4
    Last Post: 11-05-2003, 10:42 PM
