Results 1 to 7 of 7
Thread: SiS video driver for Intel D201GLY
    Sep 2005
    Bay Area
    Not sure if this is the right forum, but here's my question. I was wondering if anyone has the original SiS video driver that came with this board. I just re-did my system, but can't find my driver disk. No problem I thought, I'll just download them from Intel, besides they'll me more updated. Well, they all work great except the video driver. I'm using it with a Xenarc 700TSV and it seems to have problems when set to 800x480. The Xenarc auto senses it as 640x480 and it does not look clear, though the aspect does look like it's 800x480. Also the phase will not set correctly. The screen is shifted about 3/4" to the left and wraps around to the right side of the screen. I did not have any of these problems with the older driver. Long story short, don't update it unless you have a different setup which this hopefully won't affect.
    The driver I'm using is Ver:3.82 dated 1/17/2008 from here:
    http://downloadcenter.intel.com/Deta...13366&lang=eng
    So if any has an older driver, the one from the original disk, or a link where I can get it, I would totally appreciate it. TIA!
    May 2008
    Evergreen State
    THat looks to be the same driver as on my CD
    Sep 2005
    Bay Area
    Hummm, that's weird then. Why would it start acting so strange on this install? I've already uninstalled and re-installed with the same results.
    May 2008
    Evergreen State
    800x480 is not a standard resolution so that's why it may not show as a selectable option, but you might be able to try the " right click on desk top > display properties > advanced > adapter > list all modes " option and manually set it to 800x480... not sure if it will keep on a reboot though.
    Sep 2005
    Bay Area
    Quote Originally Posted by Kardain View Post
    The SiS driver provided with this board can be set to 800x480, and it does set it to that. The problem is the Xenarc is auto sensing it as 640x480. This problem never existed before I decided to re-do my system. I may just end up trying to reload windows again and see what happens, though it'll probably have to wait until next weekend
    Mar 2006
    Blog Entries
    1
    When I had this motherboard a long time ago I downloaded a newer version of the SiS driver on the SiS website. It was one version number higher than the one provided by Intel.
    Sep 2005
    Bay Area
    Quote Originally Posted by BlackStealth View Post
    Thanks, I'll have to check it again. I did go there, but wasn't sure which driver to download. The search for S3 Mirage, IIRC, yielded several different results.
  1. Video Driver Problem. Display blank starting at Welcome Screen
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 11-22-2008, 11:22 AM
  2. Video driver problem
    By nasa in forum General Hardware Discussion
    Last Post: 06-23-2007, 04:53 PM
  3. epia M mobo, video driver problems
    By illycut in forum General Hardware Discussion
    Last Post: 04-04-2005, 03:17 PM
  4. web tv video driver
    By Schnitz in forum General Hardware Discussion
    Last Post: 03-05-2001, 09:09 AM
