Hi all,
This is a new version for Csv2Speedzonelimit , the V1.4 .
Now, the filter for the confidence's level of trapster run well .
V1.4 As soon as . In test actually
Yes
NO
This software convert csv file on a csv Speedzonelimit file compatible .
It create:
- TRAPSTER.csv file .
The last version is : Csv2Speedzonelimit V1.5
Historique Version:
V1.5
Now, Csv2Speedzonelimit create only a TRAPSTER.csv file compatible with the setup's SpeedzoneLimit
for different origin POI files.Just put the TRAPSTER.csv on the '\Plugs\SpeedZoneLimit\' and
run the setup.exe who create itself all files for the SpeedzoneLimit plugin.
You can to choose the SkinPath in the Speedzone Tab
Don't use the speedzone setup tab. It is not complet !!!
V1.4 12/05/2009
Bad AlertGps's output files solved
Bad ZLST.TXT output file for Trapster's tab
New Tab SpeedCameraPoi.com
V1.3 28/04/2009
Concatenation is now possible
ZLST.TXT use the concatenation
Full Speedzone.ini setup
V1.2 23/04/2009
Use the new format of Zones.csv
Add a Setup Tab for the Speedzone.ini file
V1.1 04/04/2009
First Realease
Hi all,
-These version resolve an error in the output format file
for the AlertGps files .
-Add a new SpeedCameraPoi.com Tab
-In the Speedzone tab, you can to choose now the skinpath
The new version (1.5) create a compatible TRAPSTER.csv file with speedzone's plugin .
Don't use the speedzone setup tab, it is not complet.
You must to use the speedzone's setup for to create all files necessaries for speedzone .
Good use
ok i got the best CPU usage results while using
dvbviewer + CoreAVC codec
CoreAVC is not free thoughbut you can disable deblocking mode and that will get you 25% less CPU usage..
(i have no issues with MPEG2 channels, but the MPEG4 channels consume 50% of CPU!!!)
