Results 1 to 10 of 10
Thread: Thinking of making my own Front End software
    Nov 2007
    Red face Thinking of making my own Front End software
    I need your help.
    I'm thinking of developing my own frontend software. I will be asking a programmer friend of mine to help me out with this but I want to do some preliminary research and I'm hoping that maybe one of you guys could help me out.
    QUESTION 1) I want to know what's the best programming language to work with to develop a front end software that'll allow me to do the following:
    1) play audio/video formats that uniquely play on quicktime movie player
    2) play audio/video formats that uniquely play on Windows Media Player
    3) play audio/video formats that VLC plays that others don't.
    4) work with and control usb devices
    5) embed an Internet browser
    6) somehow integrate with a navigation solution. Whatever is the best solution out there atm.
    7) Not sure, but maybe I should use directX capabilities. Not sure if that's a good idea.
    QUESTION 2) What's the programming language that was used to create Centrafuse and/or streetdeck?
    Man... I'm really sorry for the noob questions. I do appreciate any help that you can provide. I just don't like the solutions out there right now.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    1. The usual response to this would be, which ever programming language you are most comfortable with.
    2. Centrafuse is done in .net (probably C# or C++) but plugins can be done in most languages.
    Vendor - Qube colin's Avatar
    Dec 2006
    VLC has wrappers for VB, C++, and Delphi. Those are your options now basically, unless you are capable of tapping into the DLLs yourself and getting the startup paramaters right. VLC is very very unstable when you're controlling it from another program so I suggest you stick with those languages where people are spending months working out the bugs.
    May 2006
    Calgary, Alberta
    Python and C. Have it run on Linux.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Qt and C++, the reason is qt-phonon media abstraction layer works on windows/mac/linux uses wmp, quicktime, or gstreamer/mplayer/vlc on linux.
    Centrafuse is managed c++ (.NET). I imagine StreetDeck also is.
    If you do go with Qt, you can use opengl which is cool.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Mar 2006
    Colorado, but Canadian!
    You can use opengl with any .net language also...
    1.9in x 2.9in -- 47mm x 73mm
    Constant Bitrate Magnezium's Avatar
    Oct 2003
    Los Angeles, CA
    OpenGL or DirectX is the best way to program. The back end of the programming can be any Microsoft language, but if you want to make your program universal (linux, mac, windows) you should program in either C++ or Java.
    Personally, I think Java is the most universal language. It's actually a very fast language if used the right way. For instance, the US Military uses Java for 99% of all of the programming for aircrafts and tanks. Guidance systems, stability systems, weapons systems, etc. use Java.
    I have been toying with the idea of building a PHP/Java front end that can be installed on any operating system.
    Just your friendly neighborhood computer specialist.
    2002 Pontiac Trans Am WS.6
    Silver/Black
    Looks like new... Wanna know why they call me "Crash"?
    Low Bitrate eigenVector's Avatar
    Apr 2009
    Personally, if you're targeting a windows environment, I favor a lot of the additional visual features available in WPF (found in .NET 3.5). So I would recommend C# program with XAML markup. Expression Blend is a great tool for building amazing looking front ends!
    Thats my 2cents
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    A well designed .NET application (same rule applies to java) can run on every platfrom also (linux and mac via the mono runtime).
    If you want to develop this quickly, I second the C#+WPF motion. I'm not sure it works on the other 2 platforms (linux, mac), but it should be a quick and easy way to get up on windows.
    I wouldn't recommend doing opengl/directx if you want to develop this quickly. They are pretty low-level APIs (opengl moreso than directx only slightly). If you do want the nice eyecandy, I recommend clutter. I'm messing around with it now and it's nice! Works on all platforms also (linux, win, mac).
    Aug 2006
    As a CS major, and considering the questions you asked. (for example, no coding needs to be done to play video formats, simply installing the correct codecs is fine) I would suggest picking an already existing open source front end, similar to (road runner before it went partially closed source), while skinning and writing plugins for any features not available, until it functions the way you want it too.
    Additionally, if you do intend to develop (and i am assuming to sell, since embarking on such a venture for free, when established frontends already exist seems strange), I would suggest programming for a thin version of linux, to maximize hardware compatibility.
    Linux also will run faster on slower hardware, which via and smaller chipsets often are.
    Good luck!
  1. Front End Software Options
    By captaintater in forum Newbie
    Last Post: 02-13-2008, 03:57 PM
  2. Why do we need car Front End software?!
    By nijel in forum Software & Software Development
    Last Post: 04-09-2006, 01:50 AM
  3. Original Cobra front end software
    By alti in forum Software & Software Development
    Last Post: 02-02-2006, 11:01 PM
  4. Front end needed for semi commercial venture
    By Orange Bus in forum Software & Software Development
    Last Post: 04-28-2005, 02:59 AM
  5. cool front end software
    By liquid_smoke in forum Software & Software Development
    Last Post: 09-02-2003, 01:23 AM
