Quote:
Originally posted by jstrain
What command are you using to copy? If you are using the "copy" command, that will truncate filenames. Try using "xcopy32" or "xcopy". Under 9x, you would use "xcopy32", but with Win2k and XP, I believe they named it just "xcopy". These commands will copy, but keep long filenames intact. You use either one with the same syntax you would with "copy".
Let us know how you make out.
Jeremy
I can't use xcopy in just plain dos outside of XP...so im trying to do xcopy winthin the command line window in XP, and we are going to see if that work's. I also tryed reinstalling the Raid Card drivers. Lets hope all this works :(
