Windows 7 CarPC, Reviewing, testing and breaking!
Hi guys just building a car pc on an Intel atom dual core board. 1Gb memory, 120GB sata laptop hdd, M4 ATX.
I though it would be interesting to see how Windows 7 runs and also how good some of the new tweaks and changes work.
I also thought it would be amusing to try and get it running as a full carpc system and see what does and doesn't work on it. I'm not live in a car at the moment so it is an ideal time to test the theory out :)
So I am listing up what works and doesn't and will do some benchmarks for speed tests.
Anything you want testing shout up with a link and I'll try and get it running :)
Working 100%
Windows
Installed Win 7 Ultimate N X86 RC0. no IE etc.
Windows Boots. need to time hibernate and standby, cold boot.
All devices detected in device manager.
nice and snappy not as much "vista lag"
Nice advanced power options
soundcard is HD audio
GFX detected correctly
Showing as 4 core 1.60GHz system
Ride runner installs 100% with no errors
Winamp 5.13 installs and plays audio 100%
RRconfig triggers UAC and loads.
Under investigation
Sound card issues with onboard sound.
RideRunner is alive and kicking with sound through RDP, had to install windows and IE versions of flash. Now testing that.
Kind of works
Works with tweaks
Works in Windows XP mode
Doesn't work at all, even a little bit
Speedtests
Graphics
CPU
Memory
I will keep this top post updated as I go through the tests.
