It is supported by RR. Look through the radio options in RR Config.
hey,
here in israel we don't get HD RADIO so i'm stuck with FM..
i purchased an HQCT (the simple one --> only radio, no amplifier and stuff) module which seems to work with the rrhqct program.
i would like to know if there is any simple way to integrate the HQCT program into the RR (i tried centrafuse and while it seems to fully support it, it actually doesn't !!)
i tried searching for a solution and came up with alot of dead ends.
please try and help.
thanks
Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
o.k - thanks.
i thought that would terminate the problem but it didn't..
i have this strange problem with my HQCT - when i go into the rrhqct program - it doesn't work. i need to pull the molex(power) and then to put it back in for it to work. even then, it works for 20 sec - 2 minutes and than hangs all over again..
what could be causing this ? could this be irq problem ? or that my HQCT is dead ?
help ?
