View Poll Results: Is this working for you?
Voters
2. You may not vote on this poll
Page 1 of 5 12345 LastLast
Results 1 to 10 of 44
Thread: Run command when power button pushed
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Thumbs up Run command when power button pushed
    I want to be able to execute a script when my power button is pushed so that my computer will be able to run an update before it powers down. I would like to be able to keep the computer from going through the shutdown process until the script has completed running.
    ANy help with this is appreciated
    CLICK HERE
    SOLUTION updated 14-JUN-2009
    Place a shortcut to it in your startup folder
    USE THE ATTACHED PROGRAM TO:
    -Intercept Windows Shutdown
    -Customizable Shutdown Options (Logoff, Hibernate, Forced Shutdown, Standby...ETC)
    -Close Ride Runner
    -Run up to 4 programs or scripts one after another
    -Disable mouse and keyboard
    -turn off monitor as soon as power button is pushed
    README
    Open the RUNNER.INI file and enter the names of the programs you wish this program to run.
    Starting with Program1.
    It will not run the next program until the previous one has closed or finished.
    EXAMPLE OF RUNNER.INI
    [PROGRAM1]
    WINDOWNAME= "NAME DISPLAYED IN DISPLAY BOX WHEN WAITING FOR PROGRAM 1. CAN BE ANYTHING"
    EXEPATH= "PROGRAM 1 EXECUTABLE AND PATH" "EXAMPLE C:\WINDOWS\NOTEPAD.EXE"
    [PROGRAM2]
    WINDOWNAME= "NAME DISPLAYED IN DISPLAY BOX WHEN WAITING FOR PROGRAM 2. CAN BE ANYTHING"
    EXEPATH= "PROGRAM 2 EXECUTABLE AND PATH" "EXAMPLE C:\WINDOWS\NOTEPAD.EXE"
    [PROGRAM3]
    WINDOWNAME= "NAME DISPLAYED IN DISPLAY BOX WHEN WAITING FOR PROGRAM 3. CAN BE ANYTHING"
    EXEPATH= "PROGRAM 3 EXECUTABLE AND PATH" "EXAMPLE C:\WINDOWS\NOTEPAD.EXE"
    [PROGRAM4]
    WINDOWNAME= "NAME DISPLAYED IN DISPLAY BOX WHEN WAITING FOR PROGRAM 4. CAN BE ANYTHING"
    EXEPATH= "PROGRAM 4 EXECUTABLE AND PATH" "EXAMPLE C:\WINDOWS\NOTEPAD.EXE"
    [RR]
    USINGIT= "SHUTDOWN Ride Runner properly if it is running (YES OR NO)"
    [MONITORCONTROL]
    USEIT= "Turn off monitor when shutting down (YES OR NO)"
    OFFDELAY= "Turn off monitor delay in seconds"
    BACKON= "Turn on monitor when RUNNER is done (YES OR NO)"
    BACKONDELAY= "Turn on monitor delay in seconds"
    [OPTIONS]
    BLOCKMOUSEANDKEYBOARDINPUT= "Disables your mouse a keyboard until RUNNER is finished (YES OR NO)"
    SPEECH= "Spoken Status of RUNNER (YES OR NO)" (SAPI required)
    SHUTDOWNWHENDONE= "Shutdown computer when RUNNER completes (YES OR NO)"
    SHUTDOWNOPTION= "Options for method of shutdown"
    /[SHUTDOWN OPTIONS]
    0 = Logoff
    1 = Shutdown
    2 = Reboot
    4 = Force
    8 = Power down
    16= Force if hung
    32= Standby
    64= Hibernate
    PB Intercept No Longer Needed
    Attached Files Attached Files
    New Age Garmin - Skin for RR
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    There you go, this should help ya.
    http://www.tutorial5.com/content/view/157/47/
    Aug 2006
    West Allis, WI
    Oh yeah forgot to mention
    Im running XP HOME
    there is no group policy editor for the home edition.
    ANy other ideas woud be greatly appreciated.
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    do you have this folder in the registry?
    HKEY_CURRENT_USER\Software\Policies\Microsoft\Windows\System\Scripts\Logoff
    Mar 2005
    Rockledge, FL
    or you can download poweroff
    http://users.telenet.be/jbosman/applications.html
    and configure it to run your script once the process of your frontend ends
    that way poweroff will sit in the system tray when the frontend process ends poweroff will run your script and then shutdown the pc
    Aug 2006
    West Allis, WI
    Quote Originally Posted by Injector View Post
    No I dont have this in the registry, checked this.
    sorry to say cant get power off to stop the shutdown process. Shutdown just kills power off.
    Aug 2006
    West Allis, WI
    Quote Originally Posted by ThunderStick View Post
    Correction power off does not work from a button press it simply shutdown your PC when the program you are running closes.
    Mar 2005
    Rockledge, FL
    but you an tell it to run a program as well, it's in the options box
    Jan 2009
    i looking into that for a while but i'm having a hard time finding one that work's
    Mar 2005
    Rockledge, FL
    have you tried making a batch file?
  1. 2008 Yaris 4 Door Sedan PC Install
    By rizaydog in forum Show off your project
    Last Post: 05-21-2009, 08:03 AM
  2. Utility to change behavior of ATX power button (e.g.: launch an app)
    By justintime in forum Software & Software Development
    Last Post: 05-08-2009, 05:45 PM
  3. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 05:56 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. I want to add a power button on my dash. Which can i use?
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 10-25-2004, 04:17 PM
