Results 11 to 20 of 28
Thread: Dual display front end
  1. #11
    May 2006
    Calgary, Alberta
    Take a look at how Air Canada does it with their enRoute system. There are video screens in the headrest of every seat on the plane. Each user has their own menu and their own mouse pointer and can watch any videos they choose to watch. Their entire system is run in Linux.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  2. #12
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Maheriano View Post
    I have to assume though that the way there setup works is that they are using virtualzation. Meaning they have one central system that holds the virtual desktops then the users access that. That of course will have its own mouse. In this case we are talking about multiple screens that are sharing on desktop PC in extended mode. Now my setup does have an option to switch over to a personal system per seat, which would have its own mouse per screen because they are each on separate systems. Anytime though when you are sharing the same desktop, you will have to share a mouse.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  3. #13
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by HiJackZX1 View Post
    or, each screen is it's own independent XSesssion -meaning separate input resources. It very well may work that each headrest is a small embedded computer (ARM) which connects to the server just to get data (the video/music). Although, I can't really think of how they accomplish the large amount of streaming they use. I just flew Emirates a few days ago. They use a system called "ICE" - Information, Communication, Entertainment. Cool idea, but the system ran like crap: slow feed back, looked old school, took ages to boot, etc. I need to get them to use nGhost+LinuxICE instead, hehe.
    Former author of LinuxICE, nghost.
    Current author of nobdy.
  4. #14
    Jul 2007
    Miami
    Quote Originally Posted by kev000 View Post
    I agree, these setups aren't powerful yet. I tried to use a setup from NComputing which is a small box that connects to a main PC via ethernet and virtualization software. My big issue is that it was so limited, no USB support (only memory sticks) and was so slow. I then looked at other virtualization companies and although they were better the speed was slow, 1ghz being there higher model. Setting up a complete system or systems, was just easier. Thankfully I drive a SUV so I had alot of space to work with. In the future virtualization will be hugeeeeeeeeee, alot of companies are switching to it as power increases.
    My setup is awkward but the way it runs is I have the main system, all the screens are connected to that. The main system pushes all the stuff like TV, Video, Music, tons of games, yadda yadda yadda. Problem is I decided that I really wanted each user the ability to do their own thing if need be. So i decided to use KVM switches, 6 of them to give the user the ability to hit a button and go to personal PC. I didnt go over board with power, I made the personal computers a modest 1.6 GHZ with 2 GB of RAM, 1 GB which is dedicated to the EWF and HORM. Each unit will run about 181.00 for MoBo, HDD, and RAM.... Thats cheaper then the units that they sell for virtualization. Also the KVMs are cool, they support audio, say your on PC2, but want to listen to PC1, you can hit hot keys to do so. The personal units do not have the ability to play on the speakers, they can only be used with headsets. I did that to make it personal and kill some complications.
    Also as a side note, Kev000 the ARM idea is actually a good one. Nice thing is, is that FLUX has thought about the potential. They have actually created a Front End for ARM system, basically anything running Windows CE 5 and up, which includes Window Mobile 2003 and up. Its currently in BETA though and will eventually need plug in designers. I think that will be a cheap and easy solution.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  5. #15
    Feb 2007
    To the CF download page!!
  6. #16
    Jul 2007
    Miami
    Quote Originally Posted by TZed9 View Post
    Wish you luck, if you need any help, I'll help you out!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  7. #17
    Feb 2007
    Thanks dude
    Having installed both RR & CF no joy in getting them running over two displays as yet. Perhaps this requires specific dual display skins?
  8. #18
  9. #19
    Jul 2007
    Miami
    To get CF to work dual screen, you have to go into setting, hold down the + key for 8 seconds to go into advanced settings mode. Then simply go into each area, like video, and set it to display 2. Only thing is, that if you do so, it can only be controlled by display to, and thats for just about every area of CF. Now to get it where both screen 1 and 2 can be used at the same time and what not, you'll have to wait till CF3.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
  10. #20
    Feb 2008
    dual display
    Hijack,
    I am working on getting a dual display done.(am still in planning stage) Wanted to know:
    - Will Zotac ION with one VGA and one DVI serve the purpose. I have read in threads that the DVI port gives out only Digital signals. One person was not able to get it work on an Analog display (which I believe our lilliputs are) by using a converter.
    - How do you use multiple sound cards. For eg if want to route my DVD / video to say display 2 (rear screen) and at the same time want that the audio for the movie should be routed to headphones then how do I do it? I would still like my main music/gps to come out through my speaker set up
    Too many questions too few answers :-)
  1. How to: Change windows shell
    By IntellaWorks in forum WinNT Based
    Last Post: 02-11-2011, 02:14 PM
  2. Vag-Scope Heads Up Display / Front End
    By puter in forum RR Plugins
    Last Post: 01-13-2011, 07:00 PM
  3. Searching for the right Front End
    By ninjatill in forum Newbie
    Last Post: 09-10-2005, 03:47 PM
  4. This is an awesome front end, and here is why:
    By WhiteRabbit in forum NeoCar Media Center
    Last Post: 08-27-2005, 10:43 PM
  5. Front end needed for semi commercial venture
    By Orange Bus in forum Software & Software Development
    Last Post: 04-28-2005, 02:59 AM
