Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Its killing me! Allocating memory in software!
    Vendor - Qube colin's Avatar
    Dec 2006
    I cant continue writing my frontend until I get this fixed! It runs off of a message system basically. Each file has a receiving function that gets messages and responds to them, this way it's modular and sort of plugin based. The problem is, I cant pass data between them!
    Anybody who knows software, here's where it gets DEEP.
    When I want to send a "broadcast" -- a message -- I call the function Broadcast with a Message(string) and some Data(pointer). It gets added to a queue and the pointer gets destroyed.
    Thats all fine, except by the time the message gets to the front of the queue, the pointer is destroyed! So, I want to COPY all the data (regardless of what type) into memory somewhere and then use that pointer instead.
    How the hell do I do that?! I tried using LocalAlloc, I tried using weird typecasting, I tried so many things! The function has to work for strings, integers, lists, and any generic objects (HID_Device objects too).
    Im developing in Delphi but that shouldn't matter.
    Nov 2007
    I picture it working like this:
    * allocate the data structure
    * put it into the queue
    * pull structures off the queue
    * pass structure around to each plugin
    * when all plugins have processed the structure, release the memory
    What is it about your code that's different from what I just described?
    Mar 2006
    Colorado, but Canadian!
    I have never been able to get global (system wide) memory allocation to work properly. Is there a reason you arent using COM or something?
    1.9in x 2.9in -- 47mm x 73mm
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    I could be way off here. If so, sorry.
    GlobalAlloc only returns a handle to a memory location. To get a true pointer, you need to call GlobalLock after GlobalAlloc.
    Also, that pointer is only useful within your process. Other processes cannot directly access that memory location in your process.
    Edit: Also, for the frontend I'm working on (DriveLine), my plan was that the plugins would communicate only with the frontend, via SendMessage. Plugins can set or retrieve certain values based on the params. So one plugin can send a command to the frontend telling it the current speed. Then, another plugin can query the frontend for the speed.
    Nov 2007
    ah... if you're dealing with multiple processes it gets a bit more complicated than what I described. In that case, used named pipes or something.
    Dec 2006
    Quote Originally Posted by NSFW View Post
    Nothing. The problem lies in putting it into the queue. If a function allocates memory, as soon as that function completes, the memory is gone. You can't keep it globally because what if that function gets called 100 times and each time puts something into a queue? you need different structures each time, and you need to keep them!
    Quote Originally Posted by 2k1Toaster View Post
    COM has unnecessary overhead for my application. Using it simply to pass messages between forms in one application is silly.
    Quote Originally Posted by ClockWorK View Post
    GlobalAlloc, LocalAlloc and HeapAlloc do return handles, however if you use LPTR or LMEM_FIXED in your flags, you automatically get a pointer because the memory is not movable. I only want it within one process.
    Your sendmessage idea is good, except what about when the information you're sending isn't a string or integer or basic type? I need to be able to call ONE function (sendmessage for example) with any type of data. It has to be able to process Integers, Strings, Chars, Pointers, StringLists (delphi thing), HID_Devices, TSongs (custom classes).
    ClockWorK's Avatar
    Oct 2003
    Michigan
    If you don't call GlobalLock, you will never have a true pointer. Seriously. But maybe you never even need a real pointer. If you call these at the load of your app, and store them in global variables, I don't see why it wouldn't work.
    AppStart:
    Allocate Memory and store handle into global variable.
    Lock Memory and store pointer into global variable.
    AppEvents:
    Use the global variables to access the allocated memory.
    AppClose:
    Unlock and free the allocated memory
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by colin View Post
    Does delphi not have a Variant type?
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    GlobalAlloc and LocalAlloc are the same in current operating systems, so use LocalAlloc just because it's easier. But yeah, your problem is local vs. global variables. locals are allocated on the stack unless declared static. globals are outside the scope of the function. That's pretty much universal for any language.
    Nov 2007
    So that is what's different from what I described.
    You need a way to allocate memory and control when it's released. In C++ you'd use "new" and I'm guessing Delphi has something similar. If you use Local/GlobalAlloc, put the handle into your queued structure, so that the code that pulls structures from the queue can also pass the handle to Local/GlobalFree (I think that's what it's called...) after passing the structure to all of the plugins.
  1. Really bad software
    By jimisbell in forum GPS
    Last Post: 05-02-2009, 11:39 PM
  2. Open Source offroad navigation software
    By JuniorGeezer in forum GPS
    Last Post: 02-22-2009, 12:22 PM
  3. LOG: Software installation and setup
    By d_sellers1 in forum Software & Software Development
    Last Post: 06-08-2006, 10:11 PM
  4. Suggestion for the Software forum
    By Confused in forum Mp3car Forum Suggestions/Comments
    Last Post: 11-02-2004, 08:55 AM
