Results 1 to 10 of 12
Thread: audiomulch 2.0???
    Jan 2009
    audiomulch 2.0???
    -I 've put virtual audio cable device as the main windows audio....
    -I 've installed asioforall
    In Audiomulch 2.0i have set vac for input ... and I have asus xonar for output ...
    In-Audiomulch himself : ... I have a graph with input at the beginning .. I have a linkto a qualizer then that is connected to ls-filter ... and that's all.... I do not know if I should do something else ...
    -then I save all this in the programfile Audiomulch and I named default.amh ( actually replaced the previous default.amh)
    -Then I put the program Audiomulch file in the startup of windows ... and when I open the pc, Audiomulch ,and my configuration open at the same time.
    Problems:
    -No sound from speaker ...
    -When I boot the pc on acc .... and then put my car on ... the pc reboot !.... if Ionly put the car on the PC boot ...i don't know why it make this
    Jan 2009
    as you can see...sound in...after equalizer...after ls_fiter(crossover)
    Jan 2009
    up
    Jan 2009
    is that good for the diagram part?
    Mar 2009
    this doesn't seem right..
    you should have 8 channels on the "SoundOut" !!
    if you can, please post the asio4all screens and the audiomulch setup screens - that will help me to help you (i'm using XONAR HDAV 1.3 in my car)
    also, what O.S are you using ? you can try replacing the drivers..
    Jul 2009
    Err no. For multichannel out you need to use SoundOut + AuxOut1 + AuxOut2 etc
    > Problems:
    Make sure that Audio is enabled (Enable Audio button on toolbar with speaker icon on it). You can make this happen when AudioMulch starts by going to Edit -> Settings, then to the Startup Actions page, and make sure the General startup actions: Enable Audio checkbox is checked. Notice that you can also specify a particular document to load there instead of doing the Default.amh thing.
    Always feel free to drop by the AudioMulch.com forums if you need help.
    Ross.
    Jan 2009
    Quote Originally Posted by nimikipod View Post
    hi i'm usingwindows xp and the same driver that wungun, has , i have the same sound card,
    how do you put 8 channels on the sound out , on the diagram???
    Jan 2009
    is that ok?
    Jan 2009
    Jul 2009
    The way you have it set now, audio input will come from the input of your soundcard. If you want to take audio from another app you'll need to assign the Virtual Audio Cables device for SoundIn in the settings dialog box. Then you have to make sure whatever is at the other end of VAC is working.
    One other thing, on the main window make sure you have Audio Enable selected (speaker button on the toolbar).
    Aside from that, the AudioMulch setup looks OK to me.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Centrafuse 2.0 Final
    By Jan_RedGTiVR6 in forum Centrafuse
    Last Post: 08-17-2008, 01:35 PM
  3. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 09:31 PM
  4. Centrafuse 2.0 RC3
    By smeesseman in forum Centrafuse
    Last Post: 05-21-2008, 10:29 PM
  5. Centrafuse 2.0 RC2
    By Ogold007 in forum Centrafuse
    Last Post: 05-21-2008, 03:59 PM
