I think you just put it in the WAC folder. You also need the VB 6.0 run files if I remember correctly.
I'm working on winamp3 skin for 800x600 touch screen. This is based on Arby's winamp skin.
This is my first winamp skin , I'm learning a lot from arby's skin.
But I don't know how to make albumcover workCan anyone help on this?
Winamp 3 800x600 Skin
well I put the albumcover.wac to wacs folder and also installed the VB6 but still it's not working .Originally posted by ddt
I think you just put it in the WAC folder. You also need the VB 6.0 run files if I remember correctly.![]()
I got error message that msvcr70d.dll is missing , well I got this file from web and now it's saying mfc70d.dll is missing..
Does anyone know how to make this album cover to work?
hmmm hey Arby~ can you help me?
Nice work! Hope you're thinking of making the skin available when you've finished!
To answer your question: Did you register the dll, or just copy it to your drive?
Here's another question - Can you launch other applications from the thinger?
C!
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
Looking real good. I like it.
As in the album art I have a program called tag & rename and it attaches album art to the id3 tag. I dunno if this helps?
- 3+ years & still no carputer!
- Done collecting parts
- Currently planning setup
Of course , I'll make it available to all of mp3car membersOriginally posted by C4M
and for dll files, I copied msvcr70d.dll just directly to windows/system32/ but I couldn't find the mfc70d.dll file![]()
DOES ANYONE SUCCESSFULLY RUN ARBY'S SKIN WITH ALBUM COVER?
Well I'm planning not to use thinger and some of other option, I'm making this for a touch screen, I though some of options(such as menu button) might not be need but you can always right click on a mouse.Here's another question - Can you launch other applications from the thinger?
the buttons on the bottom of the screen , I'll try to make it in main window (hmm come to think of it, I don't know how to do that either.![]()
YET, but I'll figure it out) but I don't know it can launch other program?? well if I have a script ,I can make it works , maybe you can help me .
well I also have a album art plugin but problem is it need to be opened from main windows(I know this is possible b/c arby did it) but I want to make it works too, only if I have working arby skin ,hmm.Originally posted by Mitokondria
register over at winamp.com forums. I worked on a full screen skin a while back and I was doing something very similar to what you are doing (different layout of course). Here's a couple links to some questions I had over there. I think they will greatly help you out.
Components inside Main Window
maki help please
The Grand aMP3 Project
Car: 96 Pontiac Grand Am
Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
Yeah actually I already searched in winamp forum and saw that messages , but didn't really say how to make album cover work . By the way are those your posts in winamp forums? Can you send me your skin? so I can study on it?Originally posted by grandamp3
maki help please
Originally posted by jtk
well I put the albumcover.wac to wacs folder and also installed the VB6 but still it's not working .![]()
Those two dll.s (actually there's a third one that go along with those 2, but it's name escapes me at the moment) are runtime dll's for VC++ MFC version 7, which is relatively new (you most likely have version 4.2 of those dlls installed). If you install the .NET framework, those dlls should be distributed with it. If not, just do a search for mfc 7 runtime and you should come across something
'03 BMW M3 6 spd.
Black/Imola Red
19's
Shuttle XPC w/ AMD 1800+
Opus 150w
Lilliput 7"
Wireless internet through my P900 and bluetooth
YEAH!!! I found the answer![]()
seems like the album cover script was made with VC++ , I got mcf70d.dll and msvcr70d.dll from MS .Net disc and copied to windows/system32 folder ,everything works GREAT!
now I know how to make my skin to work , including the bottom buttonsI'll let you know as soon as I finish. I'm already thinking about new desgin. If you are good at Photoshop , you can make a graphic (800x600) and please send it to me, I'll make it to work.
Thanks guys
