Results 1 to 5 of 5
Thread: Temperature Pop Up
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Temperature Pop Up
    Hello Every one
    Well can some 1 help me with a small snippet or a software that pops up ...
    Ok let me explain my prob
    Am in India where the normal temp is 46 C ( appox 115 F )
    and when the car is parked in heat in a parking the temp goes as hi as 65 C ( appox 150 F)
    I had the car pc in the boot earlier BUT it would not run at this HI temp ( auto Shut off )
    SO i decided to re do the whole project to be fitted in the Glove Box with a Foot vent to divert cool A/c air in this glove box ( its all done now )
    But what i want / request You Gurus to help me with is a software ( like Speed fan ) to monitor the temp of CPU ( in background ) and pop up when the temp reaches a specified value ( user adjustable )
    So that i can divert ALL the A/c air ( thru foot vent ) into the glove box and keep the CPU temp low...and as the temp goes down can re route the air back to normal flow...
    Can you pls help me with this small snippet
    Appreciate your help
    Vicky
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
    Elsewhere
    Motherboard Monitor 5 works well.
    It can also give audible alerts for high temps. IT's older, but still works, even with most newer motherboards.
    How about the Wiki?
    Dec 2003
    Hi Thanks for the suggestion
    But unfortunately it does not support my VIA MINI ITX Mobo....
    Can some 1 give me more help
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    if it doesnt support motherboard 5 and speedfan your only real computer-based solution would be an I/O device like the fusion brain. I use a fusion brain with my RRFusion plugin to monitor CPU temps, if the temps go higher than 110° it triggers a relay which runs additional fans that pull in cabin air
    Live mp3Car Facebook Chat
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    There are cheap alternatives if that's all you want http://www.dealextreme.com/details.dx/sku.7003
  1. speaker pop at car shutdown
    By andyman in forum General Hardware Discussion
    Last Post: 12-08-2007, 12:55 PM
  2. temperature controlled power with a epia tc
    By hagar2sail in forum Power Supplies
    Last Post: 07-08-2007, 11:18 PM
  3. Pop sound intermittently
    By 510SX in forum Car Audio
    Last Post: 01-28-2006, 07:12 PM
  4. Phidget Temperature sensor calibration
    By skippy76 in forum Road Runner
    Last Post: 10-05-2005, 11:47 PM
  5. Real temperature solution - what do you think?
    By dmurray14 in forum Centrafuse
    Last Post: 01-24-2005, 10:38 AM
