Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: XP sleak install
  1. #11
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Could i please have a copy of that information as well. [email protected]
    Thanks, AE.
    Quote Originally Posted by Asok
    I am running Win XP on my unit. I have killed services that I did not need and have uninstalled some of the MS software. At 1st I wanted to take the browers out. I got very close. The problem is that there are a lot of apps that use it. My machine takes more time to post than it does to boot. If you want more info ask and I will get it to you. I also know most of the files that you can remove to make a smaller footprint.
    We are, will have and forever will be...
    But not tommorrow!
  2. #12
  3. #13
    Mar 2003
    This is what I have done. If you kill your machine I am sorry and do not get mad at me! Use at your own RISK!!!
    The 1st thing I did was backup my machine with Ghost or Drive Image. I lost track of how many times I killed it. Also keep a log of what worked and what did not. I have now almost filled a notebook.
    Here is what I did. Fresh install of XP Pro then put the latest SP on it.
    I downloaded and installed Atomic XP
    I started here to see what the different services are. Then I turned off items that I did not need and some that I have installed.
    I also downloaded That way I can see what else is starting.
    You may be able to use XPLite when it comes out. Just go to
    For more tweaking I used It is nice to help in getting that start menu cut down and has lots of other great stuff.
    Stuff to get rid of
    Go to C:\windows\inf and look for a file called sysoc.inf and open it. Go to EDIT -> REPLACE and replace all the ,HIDE with just ,
    Go to Add/Remove programs then Add/Remove Windows Components. Remove only what you know you do not need. Play with removing some of the others. It may make things to stop working.
    I removed all the .hlp and the .chm files from c:\windows about 49 meg
    Remove the uninstall of patchs and updates C:\windows\$NtUninstall******
    Then I deleted "C:\WINDOWS\Driver Cache\i386\" About 75 meg
    Keep the "C:\windows\temp" and "C:\Documents and Settings\current user\Local Settings\Temp" clean
    Odds and ends
    Turn off System Restore.
    Turn off the "Pretty" junk like rolling windows
    At one time I had almost killed IE and jumped for joy but there where some problems. I save less than 1 meg. Big deal! Also, some apps require IE to run.
    I will say this one last time. Make sure you have backed up your machine and take lots of notes on what you have done. I had two images. One with no changes and one with my currect settings. Last but not least, write down what changes you have made!!!
    I did not free up a lot of hard drive space but, I did cut down the boot time. It now takes long for the machine to post then it does to boot.
    I think I am done.
    2000 Grand Prix GTP
    667 mHz PC | 512 PC 700 | DVD | ATI All-In-Wonder | 100 Gig HD | 7" LCD
  4. #14
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    You guys using XP Pro know about gpedit.msc right? Its the management console. Type that in from a command line and you will bring it up - there you can set just about any setting in XP Pro. I have not used it to trim boot time - as my carpouter is still in planning stages, but I thought I would throw that out there...
    Notice I said XP PRO version.
  5. #15
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    GPEDIT will allow config of lots of settings, but it doesn't skinny down the install size or boot time. It's a handy tool though.
    I reserve all rights in connection to each post I author, without exception.
