Windows 7 installation and lilliput 7" display
Yesterday I was trying to install Windows 7 to my Car PC but failed... Installation files were loaded successfully, but when Windows is started I saw black screen. If I list video inputs to PC input again, I will see "Out of Range" message on the screen and black screen again. Then I tried to boot Windows at "Low Resolution Mode", but result was the same - black screen. I had such problem with installed Windows XP (it appears suddenly after reboot, when I pressed "Auto Adjust Screen" button on the monitor). When I runned XP at VGA Mode and changed frequency of display to 75Hz in spite of 60Hz this problem is gone... The only thing I worry about is that I`m sure that original frequency, when I got installed Windows XP, was 60Hz and everything works fine...
Then I tried another way: I installed Windows Seven to another HDD at home, set resolution 800x600, frequency is only 60Hz and connect it to my CarPC. When I boot it, the story repeats - black screen after Windows boot logo.
I can`t figure out what is the problem - with monitor or with video card...
