Quote:
Originally posted by Loftus
could you clear this up a bit for me. okay so you can use a slave drive with DDO on it under XP if i want to transfer my music files etc... but, i'm assuming your home machine is the XP one right?
Yep
What about your car player, do you use this drive as a master with the operating system on it or do you have another drive as master and this as the slave.
Option 1. When i take the drive out my home system (with xp), and put it in the car computer, I set it to master (by changing a jumper), and the car computer boots directly from the DDO drive, straight into DOS and loads MPXPLAY.
Still my main question is this:
If the DDO software is on the master drive, will it recognise the second 40GB drive without DDO software on it?
I`m not 100% sure about this one, as I haven't tried it. BUT... I`m sure your gonna have to format your 40gig with the DDO software if your BIOS won't see the full capacity. Booting from a master drive or not, there's no way round it (afaik).
I'd like to keep my slave 40GB free of DDO software as i use this drive with my current Win95 MP3 setup in my car and i'm building a seperate system for my Van. Both MP3 players are gonna be Win95 on the 120mb Master drives. I can't have one 40GB drive as a master and expect to use it in two different computers because it will keep changing the configuration each time it boot's up.
I`m 100% sure what you mean here... do you mean you will use the same 40gig drive, and use it in both the van and car. Are you ever going to be booting from the 40 gig drive?
I hope i'm making this clear since this is not an everyday senario people would run into.
I think i`m i`m keeping up. ;) I've also had similar problems to this, but it was a fair while ago, so I don`t remember everything i`m afraid.
Also: Try experimenting! It`s the only way you can be truely sure if it's gonna work or not. I think your gonna have to go the DDO route.
