Results 1 to 10 of 11
Thread: DDO software
    Feb 2002
    Ontario, Canada
    DDO software
    Yeah i know Dynamic Disc Overlay software has been shot to hell and back on this forum but i still have a question that i could find no answer too.
    I have a single board computer that runs from a 5 slot ISA backplane. The SBC is hooked up too a 10.4" sharp LCD with touchscreen. The downside to all this is that even with the newest bios it won't recognise my 40GB slave drive full of music (master drive = 120mb running Win95). I can't use a promise card to run the 40GB drive off of since the back plane has no PCI slots.
    My question is this: If the DDO software is on the master drive, will it recognise the second 40GB drive without DDO software on it?
    The reason i don't want DDO software on the 40GB drive is because i read somewhere that you may run into problems with other operating systems. I update my MP3 archive with the 40GB on a removable rack so i can add songs from my home XP machine.
    Anyone that has used DDO software has only used it on a one HD system from what i've read here on this forum. So i nead to hear some input on this.
    Aaron, have you ever run into something like this?
    GTI - Palm IIIe controlled with Radio faceplate hack for keyboard control of WinAmp w/ Vocal Genre playlist loading.
    VW Bus - 10.4" vga lcd. Loaded with same software as above.
    Maximum Bitrate MikeHunt79's Avatar
    Aug 2001
    Cambridge & Bristol, UK
    The computer i`m typing this on is now running a slave drive with DDO on it. I`m listening to OGG's from it now.
    Here's how it`s done.... use windows XP!
    I think theres another way, I think it involes booting from the DDO drive, then pressing a ket to make it boot from another drive... never tried that tho.
    Feb 2002
    Ontario, Canada
    could you clear this up a bit for me.
    okay so you can use a slave drive with DDO on it under XP if i want to transfer my music files etc... but, i'm assuming your home machine is the XP one right? What about your car player, do you use this drive as a master with the operating system on it or do you have another drive as master and this as the slave. Still my main question is this:
    I'd like to keep my slave 40GB free of DDO software as i use this drive with my current Win95 MP3 setup in my car and i'm building a seperate system for my Van. Both MP3 players are gonna be Win95 on the 120mb Master drives. I can't have one 40GB drive as a master and expect to use it in two different computers because it will keep changing the configuration each time it boot's up.
    I hope i'm making this clear since this is not an everyday senario people would run into.
    Aug 2001
    Originally posted by Loftus
    could you clear this up a bit for me. okay so you can use a slave drive with DDO on it under XP if i want to transfer my music files etc... but, i'm assuming your home machine is the XP one right?
    Yep
    Option 1. When i take the drive out my home system (with xp), and put it in the car computer, I set it to master (by changing a jumper), and the car computer boots directly from the DDO drive, straight into DOS and loads MPXPLAY.
    I`m not 100% sure about this one, as I haven't tried it. BUT... I`m sure your gonna have to format your 40gig with the DDO software if your BIOS won't see the full capacity. Booting from a master drive or not, there's no way round it (afaik).
    I`m 100% sure what you mean here... do you mean you will use the same 40gig drive, and use it in both the van and car. Are you ever going to be booting from the 40 gig drive?
    I think i`m i`m keeping up. I've also had similar problems to this, but it was a fair while ago, so I don`t remember everything i`m afraid.
    Also: Try experimenting! It`s the only way you can be truely sure if it's gonna work or not. I think your gonna have to go the DDO route.
    Feb 2002
    Ontario, Canada
    No i'd rather not, like i said i want to be able to put this drive in any machine as a slave without reconfiguring it each time.
    Like you said i guess i gotta try and experiment a bit with it. Maybe this SBC setup will have to be put to a home use instead and have the music pulled through a home LAN setup.
    Thanks for the info though, it did clear up some issues i thought i would run into.
    Aug 2001
    No problem....
    One last thing: wtf is "Vocal Genre playlist loading"? You mention it in your sig.
    Feb 2001
    Re: DDO software
    Another thing to consider:
    http://store.firmware.com/cgi-bin/mfi/flash.html
    It should do the trick as long as you have an empty ISA slot.
    Feb 2002
    Ontario, Canada
    Re: Re: DDO software
    That's what i need! Wow i never heard of a extended BIOS like this before and for $40US bucks i might have to go that route. It's a piece of hardware that might always come in handy anyhow i guess. Maybe i'll wait till after the April computer show, might be able to find a backplane with PCI & ISA slot's.
    Thanks for the find it gives me another option.
    Feb 2002
    Ontario, Canada
    Glad you noticed that as i am quite proud of it. All 12 of my playlists are individually loaded with the announcement of their Genre in a computerized voice. I have a radio faceplate hack where the buttons are hooked up to the keyboard controller circuit board. 8 of the buttons are assigned to a Macro ( 6 for playlists, 1 for shutdown, 1 for reboot of WinAmp ). I used a program called "Advanced Text To Speech" to make wav files for each of the 12 Genre's, Alternative, Rock, Techno etc.... I then used Macro Magic to make a single button do the following example:
    The buttons activate keypresses that activate Macros that i made up with Macro Magic, Example: Turn on computer and music starts playing......Push #1 button then music stops, then plays a wav file "Alternative music ...Now loading", then loads the Alternative Dir, starts playing music and then sorts alphabetically by path and filename. The same goes with all the playlist buttons, you get a computerized female voice introducing the genre your about to hear.
    Radio Buttons:
    SCAN=Shutdown, MODE=Hold mode button in conjunction with #'s 1-6 for 6 more Playlist Dir's for a total of 12. , REP=Reboot winamp, MIX=toggles shuffle, NUMBERS 1-6=Playlist Dir's, >=Seek forward, <=Seek backward, STOP=Stop etc.....
    I do a lot of driving at night so backlit buttons were a must feature on my list, and as for the Vocal intro for the playlists..it just help's me remember what button is assigned to what playlist.
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Its been a looooong while since I delt with Win95 and chipsets with a 8.4gb limitation, but if its a slave drive, I know you can set the drive to none and still have Win2k find the drive, but I cant for the life of me remember if 95/98/ME can do the same.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
