View Poll Results: Do you like this program
Voters
9. You may not vote on this poll
  • It is a stupid idea
    0 0%
  • I like
    9 100.00%
  • I don't like
    0 0%
Multiple Choice Poll.
Results 21 to 30 of 40
Thread: A Fun Splash On application who can to launch your FrontEnd !!!
  1. #21
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Smile
    Quote Originally Posted by vicky_obee View Post
    No even this VER has errors..
    You need to first chk before you release it....
    Now the AVI file plays ... at the end of the file it just waits and does nothing
    when i click on the splash avi screen i get a buttonat the bottom of the screen QUIT.. on quitting the RR starts..
    This is not the way it should be..
    it should start RR on its own once the Avi is finished playing...
    Pls look into it
    thanks
    Ok, I see the problem .
    I see if i can do something , but iam not certain .
  2. #22
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    ALL d best
    as its a nice piece of application.. Hope u sort it out
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  3. #23
    May 2008
    Bordeaux, France
    ALL d best
    Thanks, may be a solution today , but not certain !
  4. #24
    May 2008
    Bordeaux, France
    Smile Update 0.9
    With this new version, RR or all application are launched when the AVI file is finished .
    You can always to skip your avi file with the QUIT button !
    Thanks to the french autoit forum and specially Tlem who helped me !
    Good use
  5. #25
    Low Bitrate Cycfari's Avatar
    Nov 2006
    N1 22.921 E103 54.207
    Missing Splash Config file
    Thanks for this great application. I just downloaded v0.9 & realised that the splash config file is missing. However I managed to play with it using the config. file from v0.7. Any changes btw the 2 config files?
    Also the flash choice doesn't work. It will just start the flash file & doesn't trigger the program to start after the set time. If I click quit, Splash will just exit & also dosen't trigger the prog.
  6. #26
    May 2008
    Bordeaux, France
    Quote Originally Posted by Cycfari View Post
    Thanks Cycfari,
    The splash.ini file is always generated if it don't exist on the first splash.exe's run .
    I prefer that , because the config file is always in a good format.
    I think that the 0.7 and the 0.9 splash.ini file have the same format (no change )!
    For the flash , option , i see what is my error today , and give a new version asap .
    May 2008
    Bordeaux, France
    Update 1.0
    Tis new 1.0 version solve a bug when the splash file is a swf file.
    Now, when push on the QUIT button, the application is well launched !
    Thanks all for your feed back who help me !
  8. #28
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    The matrix splash will be great in my new skin. Looks like you are the owner of half my skin! hehehe
    Any chance to loose the exit button and make it close after a desired amount of seconds?
    Thanks!
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
  9. #29
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    Can you post a screenshot?
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
  10. #30
    May 2008
    Bordeaux, France
    Quote Originally Posted by marteline View Post
    Thanks!
    I can see that !
  1. Replies: 2
    Last Post: 07-25-2008, 01:44 PM
  2. test for running application
    By dnr250 in forum WinNT Based
    Last Post: 10-02-2007, 11:23 PM
  3. Replies: 0
    Last Post: 09-23-2006, 09:38 PM
  4. Notifying child application of Hibernation wakeup
    By mullaly in forum Road Runner
    Last Post: 04-24-2006, 04:44 AM
  5. Some progress on the application...
    By Jirka Jirout in forum MacCar
    Last Post: 02-18-2006, 03:30 PM
