Is this just for RR...
Sounds cool and exploding splash screen would be awsome.
How about a download link?
It is a stupid idea
I like
I don't like
I wanted to create a new splash screen for the RR users to replace the original splash RR's screen.
I have founded in the autoit french forum a little exemple that i like.
I have added an ini file.
Now , it can use , JPG,BMP,GIF,PGN,SWF,WMV,AVI,FLV,3GP files and a matrix option ??? .
The windows splash size is the same that the picture file that you will set in the splash.ini file , so the size is automatic .
In same time, you can to define a song or a sentence.
When the splash program is finished, it run automatically the program defined in the splash.ini (not only Riderunner).
You can to change the timing (duration ans speed), the mode type (in and off), the picture name, and the windows's position (0,0 by default)
Matix option:
I hope that you you will like this one .
Differents possibility exist:
You can define in the splash.ini file
Code:################################################# # Version: 1.1a # ModeIn ModeOff possibility # # 0x00080000 ;fade-in # 0x00090000 ;fade-out # 0x00040001 ;slide in from left # 0x00050002 ;slide out to left # 0x00040002 ;slide in from right # 0x00050001 ;slide out to right # 0x00040004 ;slide-in from top # 0x00050008 ;slide-out to top # 0x00040008 ;slide-in from bottom # 0x00050004 ;slide-out to bottom # 0x00040005 ;diag slide-in from Top-left # 0x0005000a ;diag slide-out to Top-left # 0x00040006 ;diag slide-in from Top-Right # 0x00050009 ;diag slide-out to Top-Right # 0x00040009 ;diag slide-in from Bottom-left # 0x00050006 ;diag slide-out to Bottom-left # 0x0004000a ;diag slide-in from Bottom-right # 0x00050005 ;diag slide-out to Bottom-right # 0x00040010 ;explode # 0x00050010 ;implode # ################################################# [WINDOWS] WindowsName=Splash Left=0 Top=0 Width (only SWF)=800 Height (only SWF)=600 Scale (only SWF:0 showall, 1 noborder, 2 exactFit, 3 noscale)=3 Background (only SWF)=#000000 Transparency (0/255)=100 [SPLASH] SplashName(Only JPG,BMP,GIF,PGN,SWF,WMV,AVI,FLV,3GP,matrix)=kermesse.wmv Duration (ms)=4000 Speed (ms)=1000 ModeIn=0x00040010 ModeOff=0x00050010 Sound(Play/Speak)=Play AppliToLaunch=C:\Program Files\RideRunner\RideRunner.exe [SOUND] SoundToPlay(Wav, Mp3)=gmenstar.wav [SPEAK] SentenceToSpeak=Welcome in your Multi Media Car Center [MATRIX] Sound(Play/Speak)=Play SoundToPlay(Wav, Mp3)=matrix.mp3 SentenceToSpeak=I am the matrix Duration (ms)=10000
History:
Version 1.1a
I have deleted the 'Splash texte Info'
Now , the matrix font is copied into the Windows\Fonts folder automatically.
Version 1.1
I have added a duration option for the matrix option
Version 1.0
Now, RR or any application are launched when the swf is used
as splash file !
Version 0.9
Now, RR or any apllication are launched when the avi is finished !
Thanks to french forum's Tlem who helped me!
Version 0.8
Launch RR or any apllication if your splash file is an avi file .
Version 0.7
Several bugs found an issue
A 'matrix' option is added
The possibility are : JPG,BMP,GIF,PGN,SWF,WMV,AVI,FLV,3GP,matrix
A transparency possibility is added (0=hidden,255=black,100=default)
A scale possibility for SWF files only is added .
Version 0.6 (as soon as possible)
corrected a bug on launch appli
add video viewer (avi,wmv,etc...)
Version 0.5
Add a check error
Version 0.4
Add the possibility of reading a sentence
Version 0.3
Add Wav, Mp3 sounds
Version 0.2
Add PNG SWF and GIF animated.
Version 0.1
BMP,JPG and JPG only
New Age Garmin - Skin for RR
Hi ThunderStick,
No sound actually in the first version . I hope to add a sound option later .
I upload the first version today . I have forgotten something yesterday .
You can to use it for any other program that RR (ini setup possibility).
Nobody like this program ?
Hey Dude
This is a cool application..
Matter of fact wanted this for a long time.. To change the static Splash creen with some GIF format..
And you did it...
Keep it going .. may be you can develop it more to have asound fuction as well
Cheers !!!!
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
Wav and Mp3 sounds are possibles .
Good use
Add the possibility of reading a sentence !
Me , I like well![]()
Just added a test error when the exe don't exist !!!
Good use
well looks like there is some prob here..
I am using a GIF amination with sound file to sync it with each movement of the amination .. but for some reason the animation works half way .. hangs up for a few seconds .. then the sound plays all the way to the end and then rest of the animation plays....
Any idea why so. can you pls help
Thanx
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
