Results 1 to 9 of 9
Thread: iguidance issue w/ Roadrunner
    Nov 2007
    Changed my motherboard, did a fresh install and here is my issue.
    When I run RR and click on gps Iguidance shows up with the last location but does not read and SAts. If I close RR and run iguidance it works perfectly. If I leave Iguidance running then run RR and click on GPS it works. I have un-isntalled RR and Re-installed it with no success. Any ideas
    Constant Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    gps port in RR the same as iguidance? that would cause an issue.
    whichever app connects to the gps com port that will take control and stop the other.
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mp3art, RRMedia
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    eventual carpc install
    Nov 2007
    yes come port and baud rate are the same.
    Oct 2008
    Ontario, Canada
    are you having rr poll the gps for any screen functions? if so I'd look into xport.
    If not then set the gps in the rrconfig to 0 and then just have the port set in iGuidance
    Nov 2007
    what do u mean by rr poll the gps. I have the port setting on rr set to 3 which is the port number i am using.
    Oct 2008
    Ontario, Canada
    you cannot have 2 programs using the same com port
    if your gps is on port 3 then you'll need to have iguidance set on port 3.
    If you set RR to use port 3 then iguidance will not have access to port 3 since rr starts first.
    does the skin you're using have any sections other than iguidance show gps information? if so then you'll need a port splitter like xport to duplicate your gps information.
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    you'll need a program to split the com port for the gps. I use xport which is a great program. With xport you can split the gps port so iguidance and riderunner can both use the gps with different ports.
    If you don't split the ports up you will have problems using iguidance with rr.
    Jan 2006
    Dude, download and install xport. Set the input to 3 then split that over 2 other ports (example 5 and 6) set Iguidance to port 5 and RR to port 6 (within RR Config) and you won't have any issues
    Nov 2007
    i changed the port in rr and it worked, dont remember haveing rr on 0.
  1. Tired of "ABC" keyboard in IGuidance? iGQwerty
    By lostreception in forum GPS
    Last Post: 09-18-2009, 06:07 PM
  2. Issue with RoadRunner fast forwarding
    By rizaydog in forum Road Runner
    Last Post: 11-27-2008, 04:51 AM
  3. iGuidance 2.1.3 - Warning Screen Issue
    By Purplxd in forum Road Runner
    Last Post: 11-14-2005, 06:19 PM
  4. NaviVoice - iGuidance in RoadRunner
    By Purplxd in forum PowerVoice
    Last Post: 11-11-2005, 05:17 PM
  5. Replies: 0
    Last Post: 09-16-2005, 12:52 PM
