Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: WIFI Connections Handling in RR - New AI Scripts!
    Constant Bitrate l1nk's Avatar
    Jun 2007
    Sardinia Island
    Long time searching and testing but still have no success with the wifi integration in riderunner. The best solution is the wifiman by el camino but do not work properly on my install. The screen remains empty until I touch it then I only see a confused window with either network list and (overlapped) some menu links.
    After a lot of searching the web I found these AI scripts that maybe can help to build a new wifi manager system perfectly integrated in riderunner with no need to integrate the windows wifi information window.
    I'm not exactly a programmer but maybe can help to code if some expert guy trace a way
    Note that you have to install the m$ fix before or just have windows xp sp3 installed.
    Attached Files Attached Files
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by l1nk View Post
    I played around a bit with this a while back, before they had the Wireless Lan API patch for SP2, but I gave up because I didn't want to install SP3. With this new fix, it may actually be a viable solution I'll have to look into it again.
    RevFE
    My Shop
    Jun 2007
    Sardinia Island
    Quote Originally Posted by malcom2073 View Post
    It's good.
    Let me know if I can help in some way.
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have found already these scripts . You have a good idea, but is it important that the new script run well for xp , vista and 7 .
    Maximum Bitrate Dave One's Avatar
    Mar 2005
    Norfolk UK
    This would be great. I never got to grips with WIFIMan (El Camino did a great job but its the same problem as the OP) and would love to see a RideRunner plugin working. Unfortunately I lack the skills to 'make it so'!
    Vauxhall Astra SXi Car PC installed.
    Jun 2007
    Sardinia Island
    Quote Originally Posted by Enforcer View Post
    Hmmmm?
    Not sure about the meaning of your post...
    What you think about these scripts and the idea to use them to build some kind of rr plugin to handle wifi connections?
    Mar 2005
    Norfolk UK
    I think E means (and I hope I'm right), creating a RR Plugin. (Please be right..........)
    Jun 2007
    Sardinia Island
    Quote Originally Posted by Davefocus View Post
    Ok, this was my initial purpose but I'm really not able at the moment! I'm looking for some docs to learn something useful and I'm available to help if some other guy/group start to work on this.
    Jun 2004
    Westminster, MD
    Figured I'd throw this up here, see if it works for anyone. You should be able to select a wifi adapter by number (0 is usually the default) and click the button to see a list of available wireless networks. Working on the ability to connect and disconnect now, then I'll probably add auto connection.
    RevFE
    My Shop
  1. Lsx Void 3.0
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 12-11-2013, 04:05 AM
  2. Replies: 6
    Last Post: 09-13-2007, 06:07 PM
  3. usb mass storage handling in rr?
    By eelector in forum Road Runner
    Last Post: 05-16-2006, 06:10 PM
  4. Managing WiFi and GPRS Connections
    By replicant in forum Wireless Communications
    Last Post: 08-29-2005, 07:08 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
