Page 10 of 13 FirstFirst 12345678910111213 LastLast
Results 91 to 100 of 122
Thread: Open Boot Challenge 2009
  1. #91
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Final week
    I think we'll keep it open for another week then wrap this up and announce the winners. If you still want to submit your time+video+hardware specs, you've got exactly one week to do it!
    Former author of LinuxICE, nghost.
    Current author of nobdy.
  2. #92
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Well have to make a new one when i finally get mine finished. I am going to try raid 0 with SSD and see if that helps boot.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  3. #93
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Quote Originally Posted by ZX1Cruizer View Post
    I would be really careful with RAID 0 SSD, I had that on my desktop (2 x OCZ 60GB Vertex) and my G/F turned on the oven and tripped a breaker that fed the outlet the computer was on. It corrupted the RAID array, and one of the drives died. I have since RMA'd the drive and put it in my laptop. I have to say though, that RAID 0 boot was really fast. My system (12GB RAM, 2 x quad core Xeons) booted after POST in like 7 seconds. (but the BIOS took 45 seconds [server board]) I would just be wary of a power issue corrupting the RAID array in a car, that's all.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  4. #94
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    i hate you! That setup will FLY...only thing to worry about is wear leveling but that shouldn't be an issue with modern hardware.
    @Snootch:
    Disable the write cache and that won't be a problem.
  5. #95
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by kapone View Post
    Typical automotive batteries have a 70AH discharge rate.
    i.e. it can discharge 70A for 1 hour
    or
    1A for 70 hours.
    Mathematically, you make sense if you take physics into account this is simply not true unfortunately.
    As the amp draw changes, the AH rating changes. A typical car battery has an AH rating of 70 with a 3.5 amp draw. So 20 hours with 3.5 amps. If you draw 70 amps out of that battery, good luck getting a half hour let alone an hour. Standard car batteries weren't designed for that. They won't do a decent sized load for more than a few minutes. Temperature is also a big factor in this.
    If you use a deep cycle battery, you will have more luck. My deep cycle optima has a 55 AH rating. Give it a 55 amp load and it will get about 45 minutes. Even the optima is not actually designed to discharge at 55 amps.
    A better number to do calculations on is the reserve capacity. If your battery doesn't have a reserve capacity rating, don't even bother with it. It's designed for starting the car and that's it.
    Reserve capacity is the amount of time a battery can discharge at 25 amps at 80 degrees and still maintain a voltage of over 10.5 volts. My optima's reserve capacity is 120 minutes. If we do the calculation for AH at 25 amps...
    120 minutes = 2 hours
    25 amps * 2 hours = 50 AH.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  6. #96
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by justchat_1 View Post
    @Snootch:
    Seems a battery backup would be a better solution.
    I have one for each of my PCs, even without RAID.
    Tidder
    Try RevFE
  7. #97
    Jul 2007
    Miami
    @Snootch:
    Doesnt Win 7 prevent wear from happening? I read that some place, thats why I dropped the idea of EWF and HORM on my main system. Plus another thing I am scared of is that I dont know what type of raid 0 my motherboard uses. I think i saw that there is software raid (which takes longer to start) and hardware raid. Could I be wrong?
    4x 10inch Tablet
  8. #98
    Sep 2003
    New Mexico, USA
    If it's built onto the motherboard and the motherboard isn't a big expensive server board, chances are it's software/fake RAID.
    Also, Win7 does play nicer with SSDs, but afaik it doesn't have anything built in to prevent wear.
    Tidder
    Try RevFE
  9. #99
    Jul 2007
    Miami
    Quote Originally Posted by Tidder View Post
    Its a Zotac GeForce 9300 ITX.
    Well as long as it has a 5 year life span, Im cool with the SSDs kicking the bucket. Anything less then that will have me worrying all the time.
    4x 10inch Tablet
  10. #100
    FLAC SFiorito's Avatar
    May 2004
    Win7 supports TRIM, but wear leveling needs to be in the SSD controller.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
  1. Intel tips for a fast boot
    By RipplingHurst in forum General Hardware Discussion
    Last Post: 11-15-2009, 01:22 AM
  2. Open Source Turn by Turn iPhone App using Open Street Maps - Navit
    By optikalefx in forum Crowdsourced Data Collection, Open Source Mapping And Routing
    Last Post: 09-06-2009, 03:12 AM
  3. Thin Client setup help. How to boot over LAN?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 08-16-2006, 01:37 AM
  4. Replies: 6
    Last Post: 04-09-2006, 02:23 PM
  5. reversable motor for monitor?
    By more mods in forum General Hardware Discussion
    Last Post: 12-12-2004, 04:20 AM
