Page 11 of 13 FirstFirst ... 2345678910111213 LastLast
Results 101 to 110 of 122
Thread: Open Boot Challenge 2009
  1. #101
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by SFiorito View Post
    Win7 supports TRIM, but wear leveling needs to be in the SSD controller.
    Everyone is telling me that but how long will the drives stay alive? I have to assume its at least 5 years. I will mainly be reading, not writing, unless Win 7 is constantly writing for no reason.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  2. #102
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by Tidder View Post
    If it's built onto the motherboard and the motherboard isn't a big expensive server board, chances are it's software/fake RAID.
    That was true a couple of years ago but most higher end desktop boards have hardware raid.
    As far as life... it really won't die like a conventional hard drive. As the sectors die the drive just gets smaller and smaller.
  3. #103
    Jul 2007
    Miami
    Quote Originally Posted by justchat_1 View Post
    OK.... That makes sense. Thanx for clearing that up.
    *Prays I have hardware Raid 0*
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  4. #104
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I highly doubt that. Being that real hardware raid requires it's own processor and it's own ram, I don't think so.
    Even on higher end boards, it's still software/fake RAID. You show me links and I'll change my tune.
    EDIT: Just to clarify. The hardware has to support RAID, yes. But most motherboards that sport RAID, all the actual RAID function is performed by software.
    Example. This motherboard "supports" RAID. http://www.newegg.com/Product/Produc...82E16813130223 However when I needed to replace a drive and rebuild the array, I could not do it from the RAID controller's menu. It had to all be done in software after windows booted, and I noticed a constant usage of about 20% of the CPU when it was rebuilding the mirror. A real RAID wouldn't do that. Yes, the RAID would still run slow until the rebuild was done, but it wouldn't be a processor intensive process since a real RAID controller has it's own CPU to handle things like that.
    Tidder
    Try RevFE
  5. #105
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    It's handled by the chipset on the mobo exactly like a standalone raid controller. A "CPU" is a huge over-generalization.
    The hardware may not be full featured in that you need standalone software to rebuild the array (not with of of my boards) but it is true hardware raid in that there will be no additional CPU overhead when in use.
  6. #106
    Jul 2007
    Miami
    I was looking online and it turns out there is three types of RAID controllers. Software, Hybrid, and Hardware.
    My guess is maybe MoBo manufacturers are using the Hybrid version.
    Here is a PDF on how they work. http://www.adaptec.com/NR/rdonlyres/..._HWRAID_10.pdf
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  7. #107
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by ZX1Cruizer View Post
    Hybrid raid is commonly known as firmware based raid...its software raid with a bootloader basically. This was used on the very cheap raid controllers and on a few generations of intel chipsets...but really not much anymore.
  8. #108
    Jul 2007
    Miami
    AHHHH so its basically between Hardware and Software now...... Well I have read that the Zotac is pretty fast with its RAID, but I still dont know which one it is, but it doesnt matter, as long as its fast.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  9. #109
    Sep 2003
    New Mexico, USA
    I'm not sure where you are getting this information. Almost every desktop board out there uses fake/software RAID. I know of no chipset that can do RAID functions and act as a RAID micro processor. All of this processing is done by the CPU. It's basically a modified standard hdd controller with extra firmware to handle the initial boot (and yes, some do even allow you to rebuild the array from the firmware). Once the initial boot is done, software/drivers take over and the CPU does ALL the processing for the RAID.
    True hardware RAID does require a stand alone microprocessor to do the work. These do not exist on the majority of desktop boards that offer RAID, even high-end boards.
    I believe you need to read up a bit on Fake Raid, sometimes also called Host Raid. Or, post up some links and school me please.
    Tidder
    Try RevFE
  10. #110
    Jul 2007
    Miami
    Cant you call it Host RAID, you keep calling it Fake RAID, which makes me feel cheap, lol. From me reading the only ones that have Hardware RAID are high end Servers.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  1. Intel tips for a fast boot
    By RipplingHurst in forum General Hardware Discussion
    Last Post: 11-15-2009, 02:22 AM
  2. Open Source Turn by Turn iPhone App using Open Street Maps - Navit
    By optikalefx in forum Crowdsourced Data Collection, Open Source Mapping And Routing
    Last Post: 09-06-2009, 04:12 AM
  3. Thin Client setup help. How to boot over LAN?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 08-16-2006, 02:37 AM
  4. Replies: 6
    Last Post: 04-09-2006, 03:23 PM
  5. reversable motor for monitor?
    By more mods in forum General Hardware Discussion
    Last Post: 12-12-2004, 05:20 AM
