Page 9 of 13 FirstFirst 12345678910111213 LastLast
Results 81 to 90 of 122
Thread: Open Boot Challenge 2009
  1. #81
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by ZX1Cruizer View Post
    Well its only 2 sticks of RAM. I did plan on having gaming avaliable, but that also requires a good GPU and I am using a Geforce 9300 chip set, which is ok for gaming. So your saying i should upgrade to a SSD?
    An SSD will make a big difference in booting. I think this thread has shown that. I don't know any game that requires more than 2 gigs that will run decently on a Geforce 9300.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  2. #82
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by tripzero View Post
    Exactly....my point was cut back on the ram its not helping at all-its only hurting.
    An SSD will make a huge performance difference, but honestly feeding a system like that would require a few of them in a high performance raid array....lucky you don't need to do that because you won't be using the system for anything even close to what your building it for.
  3. #83
    Jan 2009
    Quote Originally Posted by justchat_1 View Post
    All good points. Another possible alternative might be to move to a dual battery setup. Keep the CarPC (and in turn all downstream devices connected to it) hooked to the second battery and use an isolator switch so that the alternator can charge both batteries when running. And even if the auxilary battery goes completely dead, your car will still start. Typical automotive batteries have a 70AH discharge rate.
    i.e. it can discharge 70A for 1 hour
    or
    1A for 70 hours.
    We are talking mA here, even if S3 draws 200mA, the auxillary battery should be good for atleast 350 hrs, or give or take 10-12 days.
    p.s. That's assuming you want all those 30 USB devices and the 8GB of RAM. 30 USB devices??? What are ya running dude??
  4. #84
    Oct 2008
    UK
    I'm sure using an SSD doesn't reduce my resume from hibernate time by much. Probably because the resume side of things is only 6 seconds (+7.5 seconds POST). I'll stick another drive in later & time it.
    @justchat_1 - I didn't mean cold-boot, I meant resume from hibernation - the key thing was the PC went through POST I've read before that those Jetway boards can POST real fast and 3 seconds resume is excellent - could you supply details of OS/RAM/Frontend/attached devices, etc.
    Darren
  5. #85
    FLAC SFiorito's Avatar
    May 2004
    Kev, what's going on? I'd figure you'd be all over this: http://linux.slashdot.org/story/10/0...Boot?art_pos=7
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
  6. #86
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by SFiorito View Post
    Meh, i know i can get Linux to boot faster than I have. The issue I take with going much further is that I'd have to make my Linux less generic and more specific to my hardware. I want to keep linuxice as hardware agnostic as possible so more people can use it. I may do my own kernel just to show the difference it can make.
    I'm nearing the point anyway where I have actual cpu and memory bottlenecks and not just hdd bottlenecks. Cold boot is a lot more cpu intensive than a resume is.
  7. #87
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by NibbleIT View Post
    As pictured in the video was my dev laptop:
    Win7 embedded stripped clean, 2Gb of ram, 500GB 7200rpm hard drive and a core 2 duo.
    my carPC:
    win7 ultimate stripped clean, 1GB of ram, 30GB SSD and a core 2 duo.
    But truthfully the biggest thing deciding resume speed is hard drive performance and os optimization. Cpu doesn't do much and memory bandwidth is far more then even a raid array could spit out.
  8. #88
    Oct 2008
    UK
    my carPC:
    I'm confused, I thought you said you had a Jetway mb connected to a M4-ATX! Are you saying your DELL laptop has a Jetway mb?
  9. #89
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Yea the carPC has the jetway mobo and m4atx..... I was just listing both specs for full disclosure.
  10. #90
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Do you mind listing what services you turned off or adjustments you made to 7embedded?
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  1. Intel tips for a fast boot
    By RipplingHurst in forum General Hardware Discussion
    Last Post: 11-15-2009, 01:22 AM
  2. Open Source Turn by Turn iPhone App using Open Street Maps - Navit
    By optikalefx in forum Crowdsourced Data Collection, Open Source Mapping And Routing
    Last Post: 09-06-2009, 03:12 AM
  3. Thin Client setup help. How to boot over LAN?
    By 2k1Toaster in forum Software & Software Development
    Last Post: 08-16-2006, 01:37 AM
  4. Replies: 6
    Last Post: 04-09-2006, 02:23 PM
  5. reversable motor for monitor?
    By more mods in forum General Hardware Discussion
    Last Post: 12-12-2004, 04:20 AM
