Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Voyager: Bluetooth OBDii for the Droid
  1. #11
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Exactly!
    OSDash is a web framework with a variety of services that can be interfaced with by a variety of applications. It includes a client library to interface with the services but all of the APIs are public and documented so anything can interface with it. Theres also a web based UI for the services that users can use for exactly what you described.
  2. #12
    Dec 2009
    Quote Originally Posted by justchat_1 View Post
    No need to re-invent the wheel: OpenOBD (yup another subproject)
    And like bugbyte said these features will be available from the OSDash project.
    Thanks JC! Although I hadn't proposed a diagnostic codes DB like what they are working on in that project I think its database could be nicely leveraged. For example if Voyager detects trouble codes present in the ECU, it could interrogate a web server and obtain detailed information, including web URLs for the user to learn more about each code.
  3. #13
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Thats actually one of my projects....but we took it a step further -> translated each manufacturer specific DTC to a universal DTC and then use the combinations of universal DTCs to determine likely causes. So instead of just EVAP system leak detected we provide trouble shooting steps like 1) Ensure the gas cap is securely tightened....etc.
    Edit:
    nice impala btw
  4. #14
    Dec 2009
    Bravo! I like it!
    I saw some chatter on the thread about storing manufacturer specific codes in the database. It seemed to die down quickly but my interest is piqued.
    I'm also sold on the OSDash ideas. To add an internet-aware adapter to the Voyager code base wouldn't take much work, in theory.
  5. #15
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    My droid is drooling. Good job, I was actually thinking about this last week.
  6. #16
    Constant Bitrate chronoglass's Avatar
    Nov 2009
    Quote Originally Posted by Bugbyte View Post
    If someone writes a car maintenance and tracking service, again, you could use your app to supply OBD information to that service or use that service to supply your app with info, if it applies.
    should get a hold of this guy. the ability to get odb2 stuff into this app would be awesome.
    I'll do the bumbling, and i'll be the idiot.
    if you've got a "stupid" question, search for some of mine!
  7. #17
    Dec 2009
    No doubt. Nice app.
    I just sent him an email.
    We'd just have to hash out a way for his app (or any app for that matter) to talk to Voyager.
  8. #18
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    aCar is a great app!! if it could integrate with voyager for fuel fillup detections that could be kinda nice. I would say mileage too but the only way to do that would be via GPS, and you would have to tell it when u were driving (which I would definitely forget to do).
  9. #19
    Dec 2009
    The info display in my dash can be selected to show me odometer (and other stuff). Word on the street is that it uses the class 2 bus (SWC) though (not regular CAN). If we just had a big VIN database with special codes in it.... ;-)
    Fuel level is working well in Voyager. Just % fuel present in the tank. no frills.
    Like on startup, if current fuel level is higher than last fuel level by X%, then start the aCar app (register a notification that user can click on to start acar app).
  10. #20
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by regulatre View Post
    Exactly...and something like 10% should be more then enough.
    Maufacturers make it very difficult to get to mileage data over OBDII to prevent tampering....most manufacturers only store it in the instrument cluster itself (well technically the CAN node representing it)....and it varies from year to year. Do a quick forum search and you should find at least one thread discussing exactly this in depth...the conclusion was that it would have to be figured out one vehicle at a time.
