Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: What's the lowest hardware you can run Win 7 on for CarPC
  1. #11
    Dec 2008
    1gb of ram for sure. the 2ghz c7 shouldnt be holding you back that much if your just running basic stuff...
  2. #12
    Low Bitrate BCasey's Avatar
    Sep 2008
    Ive got it running with an atom 1.6ghz with 512mb ram, runs fine.
    Now I havent stressed the system very much but just setting everything up and testing everything it runs great with only a half gig of ram. no issues yet.
    it also boots faster than xp and has native touchscreen support and better solid state drive support.
    New Project in the Works
    Previous Worklog here
  3. #13
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    When you say native touchscreen support, do you mean any standard Lilliput/Xenarc will basically be plug and play? I did try out Windows 7 Tiny Edition and that worked fine on my C7 2.0ghz + 512MB ram, but I had issues getting my Lilliput EBY701 and the manufacturer's touchscreen drivers to work. Basically, the touch functions wouldnt work after I resume from hibernation.
  4. #14
    Sep 2008
    A did a quick google and I think when they say native touch screen support they dont include drivers for all touch screen, its actually native multi touch but the drivers are limited to certain manufacturers i think.
    I installed my lilliput drivers, cant remember if i checked to see if the touch screen worked before, as it was the first thing i installed. it might be a moot point in that case. But I have read that the SSD support is supposed to be very good and very fast and efficient with windows 7. This was the main reason i installed windows 7, I had everything running on an xlited windows xp install but decided to try windows 7 simply because I had a SSD and its been perfect, with faster boot times than my xp install had so I've left it on.
  5. #15
    Newbie sharpmusic's Avatar
    Jun 2008
    Brooklyn, NY
    runing Win 7 happily on a 800MHZ, 1GB Ram, samsung q1 ultra
    It runs surprisingly smooth. I also upgraded Win 7 on my carPC a 1.20 ghz core2 w\2gb ram. all systems are go with the exception of the carnetix 2140, which im about to sell cuz they don't look like they plan on making a vista/win 7 driver.
  1. StreetDeck Compatible Hardware
    By ssteger in forum VaultWiki
    Last Post: 02-11-2010, 09:49 AM
  2. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 11:14 AM
  3. Run WinCE & XP together
    By ShawJohn in forum Software & Software Development
    Last Post: 11-07-2005, 05:09 PM
  4. HOW DO YOU THINK WIN XP WILL RUN if im using...
    By shezsohood in forum WinNT Based
    Last Post: 08-27-2005, 12:48 AM
  5. lowest power consumption mobo -&- safe time to run carputer
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 11-22-2003, 12:49 AM
