Looks very nice.
What i would like to see is that you can make winamp like a small player what you can do with the normal one with the - button
I'm not done with this skin yet but I want you to try this and give me your opinion. I'm gonna work on the button color (I used blue color for buttons but the color doesn't come out right on my 10.4 screen , b/c my 10.4 screen supports only upto 16bits and I made this skin with 32 bits color) anyway other function is working 95% . If you find any bug , please tell me.
known bug: Clock turns to 0:00 at 12:00 (I'm working on it)
not a bug : if you reflash the skin , the font get 3 times bigger(if you exit the winamp and restart , it will be back to normal)
Anyway download my winamp3 skin
iTouch Beta Version
and download albumcover plug-in and put the file in wacs folder in winamp directory
AlbumCover Plug-in
this plug-in needs MS framework, if you have framwork installed but still the albumcover is not working or just don't want to install framework then download following file and unzip it and put two files to the system32 folder of window directory (for w2k and wXP, I'm not sure about other windows)
Albumcover System Files
Looks very nice.
More info here----> http://www.gijsje.net
VERY nice, seemingly works fine, just one question. Can teh graphic EQ be sped up or is this a winamp thing?
(i noticed the same thing on arby's skin)
Good Work!
any screenshots?
i dont have wa3 installed
Well.. I made this player for Car PC application, I though the small player is not necessary, also some other functions such as menu button. I thought If you want to access the menu, you can use mouse(left btn) or keyboard (crtl+p) and for small player, I though since the screen is not bigger enough to run several programs which you can do on desktop computer , that's why I only put minimize button , this way you can just put WA background while you run other program.Originally posted by skoda
Looks very nice.
But if many ppl think small player button is good I can replace the min. button with small player button. It's not that hard anyway.
I think I can make it fast to load , well actually I can make it pop up instantly , but I though drawer effect is nice , more eyecatchingOriginally posted by ZanGManN
Good Work!But you think instant pop-up eq like you can do on vis or library page?
anyone got a screenshot of it?
Car: 1999 Dark Green Mustang GT Coupe
Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
Player: Empeg for now; something custom later.
www.neotechpc.com - Custom built laptops!
Here's a screenshot:
And jtk. If you don't mind I'd like to scale it down for 640 x 480. I know for me and a lot of others this is the max res we can run @.
Yes please do that for us ddt
And GREAT skin!
sure you are welcome to chnage my skin , but I think for 640x480 size , arby skin is the best, if you shrink mine to that size, the buttons and other elements will be too small for touch screen, but you can try to go though my code and change whatever you like. But I have to warn you , sice this is my first winamp skin I learned as I was coding, so the code is not clear, a lot of part was added later and some parts were redundant , I was thinking about redo all the code but , since it worked , I just left it. You might have little hard time to understand the code . I'm sorryOriginally posted by ddt
And jtk. If you don't mind I'd like to scale it down for 640 x 480. I know for me and a lot of others this is the max res we can run @. [/B]![]()
