Results 1 to 7 of 7
Thread: Windows 95 Problems
    May 2003
    Windows 95 Problems
    I am trying to run windows 95 but am running into problems because i have a USB LCD and windows 95 wont recognize my usb ports. How have other people utilized USB LCD's and windows 95 or have you guys all used Serial LCD's ???
    Jun 2002
    Norway
    hmmm, they probably have 98se installed
    have you tried google'in it?
    Richard
    "If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
    Albert Einstein
    Apr 2002
    South Coast, UK
    Sounds like either;
    1) You dont have the drivers for the USB root hub installed, or
    2) You running Win95 version A, which doesnt support USB. You want Windows 95 version B with USB support.
    (=========-) 99% complete
    AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
    All jammed in external CDROM drive case.
    Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    may i ask why youre using windows 95?
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    i think there is some kind of service pack to allow 95a to use usb
    May 2003
    I have read that about a lot of people using pentium 166 and windows 95 because the boot times were very fast, since i am using the same type maching i decided to go with 95 but i think i am going to go 98 because i cant get this problem resolved
    Apr 2000
    Little Rock, Arkansas
    I myself decided to google it and basically the answer I found was to either write your own drivers (heh, yeah right) or to upgrade to Windows 98. Even if you do somehow upgrade to Windows 95b or c, they still do a bad job of utilizing your usb port. My personal suggestion would be to install windows 98 and simply make it 98 lite.
    The Grand aMP3 Project
    Car: 96 Pontiac Grand Am
    Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
