View Poll Results: Do you run a MegaSquirt Engine Controller?
Voters
4. You may not vote on this poll
  • MS1
    1 25.00%
  • MS2
    1 25.00%
  • No
    0 0%
  • What?
    2 50.00%
Results 1 to 8 of 8
Thread: MegaSquirt >> RideRunner
    Variable Bitrate Jebus's Avatar
    Dec 2007
    Washington, USA
    Is there any interest in a MegaSquirt to RideRunner Plugin?
    RRVoice Version 1.1.0.10 BETA
    RRVCConfig Version 1.0.0.69 BETA
    RRMouseTrap Version 1.5 Beta
    RRPointer Version 1.0 BETA Update Soon
    RRTTS Testing
    RRScript Testing
    SerialSwitch In Development
    Dec 2007
    Washington, USA
    LOL, OH KAY...
    Two Whats...
    Mabe a link will help...
    MegaSquirt EFI Controller
    RRTTS Testing
    RRScript Testing
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    I dont use one at the moment but I had plans for it... would be wonderfull to be able to control everything from within RR
    what plans do you have? could everything be controlled right from the initial stuff to autotune etc?
    Blessed are the "cracked" for it is they who let in the light.
    Dec 2007
    Washington, USA
    Well, I was leaning more towards displaying the variables in labels, indicators, and Gauges...
    There are already excellent apps to configure the ECU, that is not needed...
    I have 22 variables, MS1 extra variables, that I send to RR as variables...
    I also have the RPM displayed in a nice gauge, w/RRPointer of course...
    It is very smooth in regards to needle movement, and it uses less than 20% cpu when active...
    ...JJG
    RRTTS Testing
    RRScript Testing
    Oct 2008
    Odense, Denmark
    not bad.. i was just happy to see someone smarter than me taking up the task to build such a plugin...
    do you think it would be possible to switch maps from your plugin... ie econ maps and fuel maps for racing etc?
    and would it be possible to calculate mpg etc ? if i'm not wrong megasquirt outputs data each time it fires the injectors and for how long... but i might be wrong
    Aug 2008
    Afr and boost gauges would be nice!
    Dec 2010
    San Luis Obispo, CA
    This would be EPIC!!!
    it would be great to just be able to select a few gauges and track them in real time (like megatune does). that way i can quickly take a look at a few parameters.
    as someone running a MS-II i'd love to be able to use it with my forth-coming car-pc.
    Newbie JustinNoel's Avatar
    Jan 2011
    Boston, MA, USA
    I wrote this demo for my employer ICS. Mp3Car (It's on the main page now) and TheNokiaBlog have profiled it. It uses MegaSquirt and gauges built with QML/Qt. Code is open source under the GPL so you may not be able to simply take the code and use it in RR, but you could use it as a guide. Read-only access to MS-II is trivial. Send an `a` down the serial port and get a binary blob of all the sensors back. I do this on a timer roughly 10times a second. To be complete you should read the standard MegaSquirt ini files or the firmware loaded on the MS to get the format of the byte array that comes over serial. That would let you work with any offical firmware and custom firmware. My demo is hard coded to MSExtra 2.1 firmware due to time constraints. Also my code happens to use some Linuxisms (names of serial ports), but with a little massaging should run under windows too.
    http://www.ics.com/services/qtquick
  1. Fading trust in RideRunner
    By Sinobi in forum Road Runner
    Last Post: 05-16-2010, 01:13 PM
  2. Riderunner and iGo8
    By dorrisdormouse in forum Road Runner
    Last Post: 02-16-2010, 07:21 AM
  3. Can't get RideRunner to use old Brushed Metal skin
    By Arathranar in forum Road Runner
    Last Post: 07-14-2009, 09:22 PM
  4. Riderunner issue with XM
    By chgrec in forum Road Runner
    Last Post: 04-22-2009, 06:26 PM
  5. RideRunner / Winamp issues
    By TxAxZxZ in forum RR Bug Tracker
    Last Post: 03-28-2009, 03:48 PM
