Results 1 to 10 of 14
Thread: Windows 7, Garmin Mobile PC, and ultra-low volume
    Jun 2007
    St. Louis
    I'm having an issue with audio volume on GMPC running on Windows 7. Basically...you can't hear anything the Garmin voice says...it's next to inaudible.
    If I were to put things into a perspective here... I can have the Windows volume set to Max. Winamp volume set to half, and the Car's volume set to 10 (I use the headunit) I can hear music perfectly fine, even over roadnoise. In order to hear the Garmin voice with those settings...I have to turn the car to at LEAST 22.
    I haven't had a chance to dig around in the registry for Garmin, but has anyone else run into this?
    Thanks,
    Jun 2007
    St. Louis
    no one? really? dang. I decided to hell with win7 on the carpc anyway. Going back to xp and either ewf or fbwf.
    I seem to have a lot less problems when I used xp.
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    isn't there a setting in GMPC for audio? some TTS setting? im not sure if that is for centrafuse only though
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Jun 2007
    St. Louis
    must be a CF only setting. Inside Garmin MobilePC the only thing you can do is select the voice, unlike the standalone units where you can also adjust the volume. I tried nearly everything I could from re-installing Garmin, to removing and updating drivers. Nothing fixed it. In the end, I went back to XP and the problem is solved. I wanted to use Win7...but I was having other issues with the Garmin overlay not working right and problems with application focus not functioning right. XP didn't have any of those issues so I just went back to it.
    Sep 2008
    Western Australia
    I also have the same problem in Win7 & GMPC. I think it was the same in XP, but that was too long ago to remember..
    Jun 2007
    St. Louis
    Quote Originally Posted by zillacles View Post
    Mine was bad enough that it was worthless and I didn't have the problem in XP. Might just be another 'bug' in GMPC that Garmin doesn't want to acknowledge. Just like the one in 5.00.70 where it just disappears from the screen and to get it back you have to kill the process and re-start it.
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    assuming you are using the TTS voices in garmin... All TTS voices are "low" in volume on windows for some reason. This is not a Garmin thing. As far as stability and volume control, there are other front-ends out there that dont have these problems....
    Sep 2008
    Western Australia
    Apparently someone was working on a solution, I think it was the guys who are embedding it into CF. Can't find the post though
    Jun 2007
    St. Louis
    Quote Originally Posted by ws6vert View Post
    It was with both TTS and non-TTS voices, and it was only with the Garmin App. iGuidance and iGo8 both were fine with TTS. If they are 'low' that is one thing...but to have to pause the music and turn the car's volume up to 25 when the max is somewhere in the 30's is quite extreme. Also, I don't have the problem in XP.
    Maybe the problem isn't just Garmin, but a combination of things. Maybe it's their default TTS volume, combined with something in Windows 7 (ie, sound drivers) that is the culprit. Either way, XP works so I went back to it. Someday when I have loads of time on my hands I may try it again.
    Jul 2010
    Could be win 7 decided the relative volume was too high and cut it back.
  1. Garmin Mobile PC
    By ptk in forum Garmin Mobile PC
    Last Post: 08-27-2009, 05:05 PM
