Results 11 to 20 of 25
Thread: Multichannel Equalizer [almost there]
  1. #11
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    the motherboard is a Zotac ION ITX A... (onboard sound)
    are there alternatives that would make my task more easy.... ie. route via external soundcard ?
    Blessed are the "cracked" for it is they who let in the light.
  2. #12
    Jan 2008
    it might be better to try to use a add-on sound card(pci is best due to higher bus speeds, and less latency then usb, but usb can and does work fine in most cases)
    i know that when i originally tried to setup my intel 945, i tried using onboard(its been a while, but i believe that also has a realtek chip), but couldn't get it to reliably display all of the outputs all the time in the audio processing software...
    here is where the issue comes in though-- the atom processor cannot go above 30-35% usage without causing some really nasty audio dropouts-- this was the entire reason that my 945 got removed, and replaced with a zotac 9300/pentium setup..
    so if you decide to use audio processing, you need to be very picky about what plugins you use-- some of them are more cpu intensive then others..
    audiomulch includes some very nice, small plugins that seem to work very well at very low processor requirements-- i run 2 instances of their mono line level adjustment, and don't believe that it affected the overall cpu % much at all..
    a quick note about console and audiomulch-- i have tried both, and i really like audiomulch better.. the reason is that it includes a bunch of plugins(like the level control i listed-- and i still have not found anywhere else that offers a level control plugin), and the overall layout structure allows me to feel more in control of what is going on.. console is a great program for the price, but lacks certain features that might become more critical once you start to get more involved with what you need to do with your setup..
  3. #13
    Oct 2008
    Odense, Denmark
    the problem with the software not showing all outputs on my soundcard is the biggest showstopper for me... but i will try audiomulch and see if i can get it to display all channels
    sadly my board does not have a pci slot (mini-itx board) but usb is not a problem
    but back in a bit
  4. #14
    Oct 2008
    Odense, Denmark
    nice software... but it only displays 2 outputs in the software not the 6 it should
    cant seem to find the right settings to change
  5. #15
    Oct 2008
    Odense, Denmark
    should i use the aux outputs for the other channels? so the soundout is for the main channels and the other for surround and center/sub ?
  6. #16
    Oct 2008
    Odense, Denmark
    found a guide and here is a pic that leads me to thing that what i wrote last is the case
    http://uod-true-multi-channel-mixing...24/Basic00.JPG
  7. #17
    Oct 2008
    Odense, Denmark
    hmm... i'm to "un-wise" to figure out how i capture the audio before it gets to the jacks and route it through audiomulch and then out to the jacks
    do i need virtual audio cable for that? and does that support multichannel?
  8. #18
    Jan 2008
    yes VAC supports multi channel-- you just set VAC as the primary audio output in windows, and then use AM to manipulate the audio, and send it back to the realtek outputs.
  9. #19
    Oct 2008
    Odense, Denmark
    thanks a lot.... one last thing.... what is the best way to distribute the center channel to the front speakers ie like phantom settings on some home theater amps
    i could set my system as 4 speakers and then just use a crossover, but i would like to set it for 5.1 and distribute center info to the front speakers if possible
  10. #20
    Oct 2008
    Odense, Denmark
    for some reason there is no output at the center or sub channels.... so far i only got sound from the front speakers. i have wired my plugins this way:
    windows prim. sound is set to cable1 (VAC) and my devices in mulch is set like this:
  1. FFDShow Equalizer Plugin
    By guino in forum RR Plugins No Longer Supported
    Last Post: 02-19-2011, 02:42 PM
  2. equalizer
    By psych0sys in forum Software & Software Development
    Last Post: 03-25-2008, 07:25 PM
  3. WIP of Equalizer module
    By netsuo in forum NeoCar Media Center
    Last Post: 05-08-2005, 04:19 PM
  4. is there an optical equalizer?
    By ketchup318 in forum Car Audio
    Last Post: 04-14-2005, 03:27 PM
  5. Aux. input adapter vs equalizer
    By Dima in forum General Hardware Discussion
    Last Post: 09-13-2000, 10:46 AM
