Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Multichannel Equalizer [almost there]
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    Hi
    I have read many posts about a software equalizer... but i never found anything that i could use...
    What i need is software that can EQ my outputs on the motherboard, it should be able to EQ all the outputs (4.1 or 5.1) and not only the front speakers.
    I can't use the inbuilt eq's of winamp etc. as i dont use them.
    Just before i post this i will say that i have played vith VAC so i only need an eq app that supports multichannel... i guess
    Blessed are the "cracked" for it is they who let in the light.
    Oct 2008
    Odense, Denmark
    found a section in the wiki.... but it did not include info on multichannel setups... or did i miss something?
    Oct 2008
    Odense, Denmark
    anyone that can help guide me on how to eq a multichannel soundcard are most welcome to post comments.
    What I wanted are:
    1. EQ each channel indepent...
    2. Time align them, but can be left out since my car is rather small
    3. Adjust the Voloume of each channel indepent. most soundcards can do this
    Oct 2008
    Odense, Denmark
    is there someone that have tried this before and would like to share?
    Jul 2010
    France
    depends on which audio controller you have on your mobo... but if you have realtek audio then I can help you. There's a dll that exports useful interfaces to control its integrated EQ and a few other stuff. (but you won't be able to EQ each channel separately).
    For volume level control there's an api for that (winmm.dll, take a look at http://msdn.microsoft.com/en-us/library/ms925312.aspx)
    what language do you code with?
    Oct 2008
    Odense, Denmark
    i'm not a coder... and beeing able to eq each channel is a must. There are plenty options if i would only eq the front channels.
    Jan 2008
    you could use a program like console or audio much to add as many eq's and level adjustments as your processor can handle..
    Oct 2008
    Odense, Denmark
    i tried that also, but it was not clear how to set it up to handle surround channels etc... either that or i'm a tad to stupid to figure it out
    Jan 2008
    what board/audio card are you using?
    the audio processing does take a little to setup, and i know i had some problems with my onboard sound on my old 945...
    Oct 2008
    Odense, Denmark
    the chip is a realtek alc662
    the system is taken apart as i'm in the process of making it ready for the pc... but my laptop has almost the same chip (3 jacks) so i could use that as a test machine
  1. FFDShow Equalizer Plugin
    By guino in forum RR Plugins No Longer Supported
    Last Post: 02-19-2011, 02:42 PM
  2. equalizer
    By psych0sys in forum Software & Software Development
    Last Post: 03-25-2008, 07:25 PM
  3. WIP of Equalizer module
    By netsuo in forum NeoCar Media Center
    Last Post: 05-08-2005, 04:19 PM
  4. is there an optical equalizer?
    By ketchup318 in forum Car Audio
    Last Post: 04-14-2005, 03:27 PM
  5. Aux. input adapter vs equalizer
    By Dima in forum General Hardware Discussion
    Last Post: 09-13-2000, 10:46 AM
